[geomoose-psc] git workflow notes on demo
Eli Adam eadam at co.lincoln.or.us
Fri Apr 10 17:45:23 PDT 2015
At some point we could discuss an alternate demo branch(es).  This would be
another branch that we run another demo off of.  This could be especially
useful for having people test issues in review.  A workflow like: fix the
issue in master, config alt demo to be relevant to that fix, put issue into
review and link to alt demo, then reporter can test the issue without
figuring out how to run trunk.
Eli
On Fri, Apr 10, 2015 at 5:09 PM, James Klassen <klassen.js at gmail.com> wrote:
> It still could be documented better.   Like how to update a branch other
> than master, etc.
> On Apr 10, 2015 7:01 PM, "Eli Adam" <eadam at co.lincoln.or.us> wrote:
>> On Fri, Apr 10, 2015 at 3:57 PM, James Klassen <klassen.js at gmail.com>
>> wrote:
>>> I should note if you have local changes in a submodule, they need to be
>>> separately pushed before running this script.  Otherwise, the referenced
>>> commits won't be at github.
>>> On Apr 10, 2015 5:53 PM, "James Klassen" <klassen.js at gmail.com> wrote:
>>>> https://github.com/geomoose/geomoose-utils/blob/master/update_to_master.sh
>> Ah, great, even better place for it.  I should have looked there first.
>> Thanks, Eli
>>> On Apr 10, 2015 4:34 PM, "Eli Adam" <eadam at co.lincoln.or.us> wrote:
>>>>> Hi Jim,
>>>>> You diligently keep the sub-modules in geomoose/geomoose/ updated so
>>>>> that the demo is reflective of the current commits.  Can you note the
>>>>> commands that you use to push these two commits?
>>>>> https://github.com/geomoose/geomoose/commit/5f2c3b65717462aa822827efca90681d9898a121
>>>>> https://github.com/geomoose/geomoose/commit/5955f838d6e60bc632b1e1847699b089191aa07f
>>>>> I appreciate you keeping things current.
>>>>> Thanks, Eli
>>>>> _______________________________________________
>>>>> geomoose-psc mailing list
>>>>> geomoose-psc at lists.osgeo.org
>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geomoose-psc
URL: <http://lists.osgeo.org/pipermail/geomoose-psc/attachments/20150410/4691ef22/attachment.html>
More information about the geomoose-psc mailing list
