[geomoose-psc] Google Geocoder
Dan Little theduckylittle at gmail.com
Fri Jul 1 07:37:55 PDT 2016
Schuyler Earl. Good luck.  It's like 12 projects ago for him.
On Fri, Jul 1, 2016 at 9:35 AM, James Klassen <klassen.js at gmail.com> wrote:
> Do we know who was running geocoder.us?  Maybe we could get it fixed.
> On Jul 1, 2016 05:03, "Dan Little" <theduckylittle at gmail.com> wrote:
>> Hey Folks,
>> geocoder.us appears to be defunct. The website doesn't load and there
>> certainly does not appear to be any geocodes being returned.  This was
>> our default geocoder.
>> The other geocoder with which we have code is the Google Geocoder.
>> I'm fixing it up right now to work (it wasn't) and to also include an
>> appropriate credit/disclaimer.  However, I'm a bit worried as we are
>> probably running afoul the Google TOS.  I see a few options:
>> 1. Run with it. We're a very small fish in a very large pond.
>> 2. Do not include a Geocoder by default but provide instructions for
>> adding back in the Google geocoder (including setting an API key).
>> This runs ... "less" afoul the TOS depending on how you read them.
>> 3. Remove all the geocoders.  They're all broken.  Folks may not like
>> to see the code disappear.
>> Long term (and I will file a ticket to this regard) we should probably
>> write our own Geocoder instructions or write a crappy
>> DIY/off-the-shelf-libs geocoder that works with the default parcel
>> data.
>> Cheers,
>> -Duck
>> Reference tickets:
>> - https://github.com/geomoose/geomoose/issues/150
>> - https://github.com/geomoose/geomoose/issues/152
>> geomoose-psc mailing list
>> geomoose-psc at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geomoose-psc
More information about the geomoose-psc mailing list
