[geomoose-psc] Google Geocoder
Eli Adam
eadam at co.lincoln.or.us
Fri Jul 1 09:22:35 PDT 2016
Good point Bob, I think we need two discussions: What to do past
2.9.1? and What to do for 2.9.1?
For beyond 2.9.1, I favor c, especially if Mapzen or something else is
a viable option. If there aren't viable options, then b sounds good
for long term.
For 2.9.1, I think any options will work except we might want to
decide based on the long term. i.e. if the long term route is b, we
should do that now for 2.9.1 too.
Eli
On Fri, Jul 1, 2016 at 9:16 AM, Basques, Bob (CI-StPaul)
<bob.basques at ci.stpaul.mn.us> wrote:
> My vote would be for “a”, with a Note about probable deprecation of service
> in the demo. Then figure out what the next version will look like.
> bobb
> On Jul 1, 2016, at 11:08 AM, Dan Little <theduckylittle at gmail.com> wrote:
> Should we:
> a. Deliver 2.9.1 with Google.
> b. Deliver 2.9.1 without any 'enabled' Geocoder (comment out the entry
> in the mapbook) and write a quick "How To Enable The Googs".
> c. Deliver 2.9.1 with an alternative geocoder to replace geocoder.us
> and leave the google code dormant as it was in 2.9.
> Aside:
> I'm not sure which of a-c would necessitate switching to 2.10 but
> these are all methods for addressing the same 'bug.'
> On Fri, Jul 1, 2016 at 10:41 AM, Eli Adam <eadam at co.lincoln.or.us> wrote:
> There is this,
> https://mapzen.com/products/search/?lng=-124.01556&lat=44.66743&zoom=12
> not certain on licensing but seems very unrestricted.
> On Fri, Jul 1, 2016 at 8:03 AM, Dan Little <theduckylittle at gmail.com> wrote:
> We could ship 2.9.1 with Google and do a next-step. 2.9.1, I think,
> is basically ready for testing.
> On Fri, Jul 1, 2016 at 9:58 AM, James Klassen <klassen.js at gmail.com> wrote:
> It may be old school, but I didn't see any good alternatives mentioned
> though.
> 1. Violate Google TOS
> 2. Cripple the Demo, but let people add it back. Also, removes it from
> regular testing.
> 3. Who needs geocoders anyway? This might be OK for the parcel app users
> because they probably already have better local data anyway. But it doesn't
> help anyone else.
> Also, this means the 2.9.0 on OSGeo Live should be fixed.
> On Jul 1, 2016 09:49, "Dan Little" <theduckylittle at gmail.com> wrote:
> geocoder.us was useful but the momentum for geocoding TIGER files in
> Berkeley databases is not considered particularly modern.
> On Fri, Jul 1, 2016 at 9:48 AM, James Klassen <klassen.js at gmail.com>
> wrote:
> I think an email saying we noticed it was down and offering to help
> maintain
> it might be worthwhile.
> Yes, a nice courtesy.
> I guess my real question is if geocoder.us is still useful to the
> community
> or has the world moved on to something else (OSM)? If it is useful to
> us
> and to others, we should look into helping maintain/support it.
> On Jul 1, 2016 09:37, "Dan Little" <theduckylittle at gmail.com> wrote:
> Schuyler Earl. Good luck. It's like 12 projects ago for him.
> On Fri, Jul 1, 2016 at 9:35 AM, James Klassen <klassen.js at gmail.com>
> wrote:
> Do we know who was running geocoder.us? Maybe we could get it fixed.
> On Jul 1, 2016 05:03, "Dan Little" <theduckylittle at gmail.com> wrote:
> Hey Folks,
> geocoder.us appears to be defunct. The website doesn't load and
> there
> certainly does not appear to be any geocodes being returned. This
> was
> our default geocoder.
> The other geocoder with which we have code is the Google Geocoder.
> I'm fixing it up right now to work (it wasn't) and to also include
> an
> appropriate credit/disclaimer. However, I'm a bit worried as we are
> probably running afoul the Google TOS. I see a few options:
> 1. Run with it. We're a very small fish in a very large pond.
> 2. Do not include a Geocoder by default but provide instructions for
> adding back in the Google geocoder (including setting an API key).
> This runs ... "less" afoul the TOS depending on how you read them.
> Running a demo of geocoding in GeoMoose seems fine as a demonstration.
> We probably shouldn't distribute a working demo with an API key.
> Right now, it would take work to run a different demo than what we
> distribute as the demo. So that makes a case for remove it from the
> demo.
> With something like this, it seems providing directions and maybe an
> example (but not working with an API key) is the correct path. That
> allows the user to evaluate the TOS and whether they are appropriate
> for them.
> 3. Remove all the geocoders. They're all broken. Folks may not
> like
> to see the code disappear.
> Long term (and I will file a ticket to this regard) we should
> probably
> write our own Geocoder instructions or write a crappy
> DIY/off-the-shelf-libs geocoder that works with the default parcel
> data.
> Let's avoid writing geocoders, even lame parcel ones.
> Best regards, Eli
> Cheers,
> -Duck
> Reference tickets:
> - https://github.com/geomoose/geomoose/issues/150
> - https://github.com/geomoose/geomoose/issues/152
> geomoose-psc mailing list
> geomoose-psc at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-psc
> "I'm not interested in preserving the status quo; I want to overthrow it.”
> - Niccolo Machiavelli
More information about the geomoose-psc
