[geomoose-psc] Google Geocoder
Dan Little theduckylittle at gmail.com
Fri Jul 1 12:15:46 PDT 2016
A pile of effort for minimal gain to our application.
If we want to release our stuff then. we can't be dependent on a service we
were grifting.
On Jul 1, 2016 21:14, "James Klassen" <klassen.js at gmail.com> wrote:
> What about d) figure out what happened to geocoder.us?
> On Jul 1, 2016 14:07, "Eli Adam" <eadam at co.lincoln.or.us> wrote:
>> On Fri, Jul 1, 2016 at 9:31 AM, Basques, Bob (CI-StPaul)
>> <bob.basques at ci.stpaul.mn.us> wrote:
>> > More discussion needed for anything other than “a”.
>> > We have some options we’ve been using locally that might work as a
>> > replacement, but need to talk more about it first.  Hence my, release
>> now,
>> > and move to change later.
>> If we have no plans for "c" to come about in the near- or mid- term,
>> then "b" would be the immediate and mid-term option.  "a" to just
>> delay "b" is not a good option.  If we're going with "b" in the
>> mid-term, let's go with "b" now.
>> Those are my thoughts, Eli
>> > bobb
>> > On Jul 1, 2016, at 11:24 AM, Dan Little <theduckylittle at gmail.com>
>> wrote:
>> > In terms of level of effort:
>> > a. This is already done in master.
>> > b. This would be 30-45 minutes worth of work.
>> > c. Probably an hour, maybe two hours with testing.
>> > I'm willing to do "b" if folks think that dropping the geocoder from
>> > the demo is a viable move.
>> > On Fri, Jul 1, 2016 at 11:22 AM, Eli Adam <eadam at co.lincoln.or.us>
>> wrote:
>> > Good point Bob, I think we need two discussions: What to do past
>> > 2.9.1? and What to do for 2.9.1?
>> > For beyond 2.9.1, I favor c, especially if Mapzen or something else is
>> > a viable option.  If there aren't viable options, then b sounds good
>> > for long term.
>> > For 2.9.1, I think any options will work except we might want to
>> > decide based on the long term.  i.e. if the long term route is b, we
>> > should do that now for 2.9.1 too.
>> > Eli
>> > On Fri, Jul 1, 2016 at 9:16 AM, Basques, Bob (CI-StPaul)
>> > My vote would be for “a”, with a Note about probable deprecation of
>> service
>> > in the demo.  Then figure out what the next version will look like.
>> > bobb
>> > On Jul 1, 2016, at 11:08 AM, Dan Little <theduckylittle at gmail.com>
>> wrote:
>> > Should we:
>> > a. Deliver 2.9.1 with Google.
>> > b. Deliver 2.9.1 without any 'enabled' Geocoder (comment out the entry
>> > in the mapbook) and write a quick "How To Enable The Googs".
>> > c. Deliver 2.9.1 with an alternative geocoder to replace geocoder.us
>> > and leave the google code dormant as it was in 2.9.
>> > Aside:
>> > I'm not sure which of a-c would necessitate switching to 2.10 but
>> > these are all methods for addressing the same 'bug.'
>> > On Fri, Jul 1, 2016 at 10:41 AM, Eli Adam <eadam at co.lincoln.or.us>
>> wrote:
>> > There is this,
>> > https://mapzen.com/products/search/?lng=-124.01556&lat=44.66743&zoom=12
>> > not certain on licensing but seems very unrestricted.
>> > On Fri, Jul 1, 2016 at 8:03 AM, Dan Little <theduckylittle at gmail.com>
>> wrote:
>> > We could ship 2.9.1 with Google and do a next-step.  2.9.1, I think,
>> > is basically ready for testing.
>> > On Fri, Jul 1, 2016 at 9:58 AM, James Klassen <klassen.js at gmail.com>
>> wrote:
>> > It may be old school, but I didn't see any good alternatives mentioned
>> > though.
>> > 1. Violate Google TOS
>> > 2. Cripple the Demo, but let people add it back.  Also, removes it from
>> > regular testing.
>> > 3. Who needs geocoders anyway?  This might be OK for the parcel app
>> users
>> > because they probably already have better local data anyway.  But it
>> doesn't
>> > help anyone else.
>> > Also, this means the 2.9.0 on OSGeo Live should be fixed.
>> > On Jul 1, 2016 09:49, "Dan Little" <theduckylittle at gmail.com> wrote:
>> > geocoder.us was useful but the momentum for geocoding TIGER files in
>> > Berkeley databases is not considered particularly modern.
>> > On Fri, Jul 1, 2016 at 9:48 AM, James Klassen <klassen.js at gmail.com>
>> > wrote:
>> > I think an email saying we noticed it was down and offering to help
>> > maintain
>> > it might be worthwhile.
>> > Yes, a nice courtesy.
>> > I guess my real question is if geocoder.us is still useful to the
>> > community
>> > or has the world moved on to something else (OSM)?  If it is useful to
>> > us
>> > and to others, we should look into helping maintain/support it.
>> > On Jul 1, 2016 09:37, "Dan Little" <theduckylittle at gmail.com> wrote:
>> > Schuyler Earl. Good luck.  It's like 12 projects ago for him.
>> > On Fri, Jul 1, 2016 at 9:35 AM, James Klassen <klassen.js at gmail.com>
>> > wrote:
>> > Do we know who was running geocoder.us?  Maybe we could get it fixed.
>> > On Jul 1, 2016 05:03, "Dan Little" <theduckylittle at gmail.com> wrote:
>> > Hey Folks,
>> > geocoder.us appears to be defunct. The website doesn't load and
>> > there
>> > certainly does not appear to be any geocodes being returned.  This
>> > was
>> > our default geocoder.
>> > The other geocoder with which we have code is the Google Geocoder.
>> > I'm fixing it up right now to work (it wasn't) and to also include
>> > an
>> > appropriate credit/disclaimer.  However, I'm a bit worried as we are
>> > probably running afoul the Google TOS.  I see a few options:
>> > 1. Run with it. We're a very small fish in a very large pond.
>> > 2. Do not include a Geocoder by default but provide instructions for
>> > adding back in the Google geocoder (including setting an API key).
>> > This runs ... "less" afoul the TOS depending on how you read them.
>> > Running a demo of geocoding in GeoMoose seems fine as a demonstration.
>> > We probably shouldn't distribute a working demo with an API key.
>> > Right now, it would take work to run a different demo than what we
>> > distribute as the demo.  So that makes a case for remove it from the
>> > demo.
>> > With something like this, it seems providing directions and maybe an
>> > example (but not working with an API key) is the correct path.  That
>> > allows the user to evaluate the TOS and whether they are appropriate
>> > for them.
>> > 3. Remove all the geocoders.  They're all broken.  Folks may not
>> > like
>> > to see the code disappear.
>> > Long term (and I will file a ticket to this regard) we should
>> > probably
>> > write our own Geocoder instructions or write a crappy
>> > DIY/off-the-shelf-libs geocoder that works with the default parcel
>> > data.
>> > Let's avoid writing geocoders, even lame parcel ones.
>> > Best regards, Eli
>> > Cheers,
>> > -Duck
>> > Reference tickets:
>> > - https://github.com/geomoose/geomoose/issues/150
>> > - https://github.com/geomoose/geomoose/issues/152
>> > _______________________________________________
>> > geomoose-psc mailing list
>> > geomoose-psc at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/geomoose-psc
>> > "I'm not interested in preserving the status quo; I want to overthrow
>> it.”
>> > -  Niccolo Machiavelli
>> > "I like nonsense; it wakes up the brain cells."
>> > - Dr. Seuss
URL: <http://lists.osgeo.org/pipermail/geomoose-psc/attachments/20160701/bc3f1b08/attachment.html>
More information about the geomoose-psc mailing list
