[geomoose-psc] Publishing the Ledger
Eli Adam eadam at co.lincoln.or.us
Mon Dec 11 11:45:24 PST 2017
On Mon, Dec 11, 2017 at 10:27 AM, Eli Adam <eadam at co.lincoln.or.us> wrote:
> On Mon, Dec 11, 2017 at 10:17 AM, Dan Little <theduckylittle at gmail.com> wrote:
>> I've created a Git repository on www.
>> 1. I created a new 'ledger' account on www.
>> 2. I initialized a bare git repo.
>> 3. I put a new public key of mine into authorized_keys.
>> 4. I added www as origin, and set it to master's upstream on my local clone.
>> 5. There is a summary.py file that will summarize the CSV file.
>> If there's anyone (other than Jim) who would like me to add their public key
>> to the repo, please let me know.  I will do so and send you the appropriate
>> git-clone command.
> I'll give this a go as well.  You should be able to find my public key
> already on www.
Thanks!  I've successfully cloned the repo.  (re)Reading this helped
me out, https://superuser.com/questions/232373/how-to-tell-git-which-private-key-to-use#232406
Eli
> Thanks, Eli
>> Cheers!
>> On Sat, Dec 9, 2017 at 12:36 PM, Jim Klassen <klassen.js at gmail.com> wrote:
>>> Ok.  CSV or maybe even just markdown.  Whatever keeps it simple.
>>> On 12/08/2017 01:47 PM, Dan Little wrote:
>>> CSV is fine with me as well. That does allow for easy diffing and use of
>>> spreadsheet programs as desired.  I will probably also include a "check
>>> balance" Python script for doing some basic reporting.  There are CLI and
>>> text based ledger programs.  I really don't want to go deep into a format
>>> debate or over-do the accounting for what really is a simple
>>> money-in-money-out + voting record.
>>> In terms of backup and redundancy, I will have the repo cloned locally,
>>> which gets backed up regularly, and those who have interest will also be
>>> able to do pulls.  The bank account should also have some information and
>>> I'll put Nancy and Steve's contact information in the repository so that if
>>> something unfortunate were to happen, someone will be able to pick up the
>>> torch and continue on.
>>> On Fri, Dec 8, 2017 at 11:55 AM, Eli Adam <eadam at co.lincoln.or.us> wrote:
>>>> Thanks for starting this Dan.  Github doesn't seem quite right (unless
>>>> open source projects also got one private repo for security, finances,
>>>> and other non-public issues)
>>>> On Fri, Dec 8, 2017 at 7:25 AM, James Klassen <klassen.js at gmail.com>
>>>> wrote:
>>>> > Thoughts:
>>>> > A plain text format might be better suited with git.  Org would be
>>>> > ideal (it
>>>> I was also thinking of some form of text format.
>>>> > can save formulas and recalculate like spreadsheets) except for most of
>>>> > the
>>>> > magic only works in emacs, and despite emacs clearly being the one true
>>>> > editor, I realize not everyone is ready to accept that yet.  But, some
>>>> > other
>>>> > format like CSV or markdown table could work too.  Mostly, I'd like to
>>>> > be
>>>> CSV is simple text and can still be used by spreadsheet programs.
>>>> > able to use diff/blame to make it easy to audit who changed what when.
>>>> Yes, changesets was the point.  I suppose that there is not going to
>>>> be a lot of churn on this file so I could download 10 copies of binary
>>>> files and open and look at them.  But that is using me (a human) to do
>>>> diffs.
>>>> > The geomoose.org server is only sporatically backed up right now
>>>> > (mostly
>>>> > before and after larger system config changes and GeoMoose releases).
>>>> > I
>>>> > have been assuming the day to day changes are covered by what is on
>>>> > github
>>>> > and people's local clones.  Thus is this isn't living on github, we
>>>> > should
>>>> > be extra sure we are maintaining a separate  copies (that are kept up
>>>> > to
>>>> > date) off server.
>>>> > I have no problem with git over ssh (or git over email).  That is how
>>>> > it was
>>>> > designed to work in the first place.  We could go as simple as using
>>>> > the
>>>> > geomoose account or even easily setup gitolite.
>>>> Every PSC meeting that has a report about finances could be a prompt
>>>> for PSC members to copy the repo somewhere.
>>>> > We should maybe look at using GPG signed commits (git commit -S) for
>>>> > this
>>>> > repo.
>>>> Maybe.  I don't expect that we'll have confusion over who is making
>>>> the commits.
>>>> Best regards, Eli
>>>> > On Dec 8, 2017 8:44 AM, "Dan Little" <theduckylittle at gmail.com> wrote:
>>>> >> Hey Folks,
>>>> >> I have put together the start of a 'ledger'. Right now it's a
>>>> >> spreadsheet
>>>> >> in .ODS format. Barring objections, I'd like to create a repository on
>>>> >> the
>>>> >> web-server which can be accessed over SSH to store the ledger.  This
>>>> >> can
>>>> >> give folks who are interested access without putting _everything_ up
>>>> >> on
>>>> >> GitHub.
>>>> >> For those interested, we have $1,126 available at present.
>>>> >> Thanks again!
>>>> >> _______________________________________________
>>>> >> geomoose-psc mailing list
>>>> >> geomoose-psc at lists.osgeo.org
>>>> >> https://lists.osgeo.org/mailman/listinfo/geomoose-psc
More information about the geomoose-psc mailing list
