[geomoose-psc] quick website question, where to put geomoose as a technology?
TC Haddad tchaddad at gmail.com
Tue Oct 17 16:25:24 PDT 2017
I notice that there is nothing listed under Client:
Home <http://osgeo.getinteractive.nl/> » Choose a project
<http://osgeo.getinteractive.nl/choose-a-project/> » Information Technology
<http://osgeo.getinteractive.nl/choose-a-project/information-technology/> »
Client
<http://osgeo.getinteractive.nl/choose-a-project/information-technology/client/>
Would it make sense to go there?
Personally, for the purposes of the OSGeo website (targeted at new users
wanting to convert to FOSS) would call GeoMoose a "Configurable Map
Viewer", which to me means it is essentially an easy to set up client. The
advanced features mentioned by Jim and Bob are also great, but are a bonus
for most users seeking to fulfill the first use case.
Projects that fit under "Portal" in my mind would be things like GeoNetwork
and GeoNode, but maybe I am being to limited in my thinking?
Tanya
On Tue, Oct 17, 2017 at 4:10 PM, Basques, Bob (CI-StPaul) <
bob.basques at ci.stpaul.mn.us> wrote:
> Jody,
> It’s actually usable in both of the those categories.  I would lean a bit
> more towards the Portal description though.   GeoMoose was put together in
> the forst place to handle the dissemination of large GeoSpatail datasets
> covering a large area, while still allowing the users to get at the data
> they needed for their little corner of the map world.
> At it’s heart, it was intended  to oraganize and distribute many data
> layers while also aloow for a visual interface for the discovery of the
> spatially referenced data (A Portal).  The GeoMoose demo is packaged as a
> Portal too.  But a key point is that while GeoMoose can connect to other
> Web services.  It’s essentially a Javascript application that can be used
> to mine OGC services.  The Demo has these services originating from
> MapServer.  GeoMoose can also use Tiles, raster and vector, as well as be
> configured to run in standalone mode.  It really only requires a Browser
> and some datasets to operate.  A web server helps, but I think I could set
> it up to run from a flat file location too (I can be corrected here, and
> proably will :c).
> It’s really (REALLY) hard to describe all the GeoMoose capabilities
> actually.  I’m of the mind to figure out how to pachage it up in more than
> on way actually, but it’s just not been gotten to yet.  Others here will
> likely say I’m not 100% with any of this too.
> bobb
> On Oct 17, 2017, at 5:48 PM, Jody Garnett <jody.garnett at gmail.com> wrote:
> I was trying out the website, filling in a website survey that was sent to
> participants last week (and the discussion list this week).
> One thing that startled me was where geomoose lives in the
> choose-a-project wizard.
> choose a project <http://osgeo.getinteractive.nl/choose-a-project/> > information
> technology
> <http://osgeo.getinteractive.nl/choose-a-project/information-technology/> >
> web services
> <http://osgeo.getinteractive.nl/choose-a-project/information-technology/web-services/> -
> yes!
> technology
> portal
> <http://osgeo.getinteractive.nl/choose-a-project/information-technology/portal/>
> - no?
> Did I do a bad job of describing "portal"? It used to be called
> "intengrated" but then everyone chose it, now that it is called portal
> nobody has chosen it.
> Goal is to describe an application (like GeoMOOSE?) that can be used for
> web mapping out of the box using only configuration ... or do I have the
> wrong idea about GeoMOOSE?
> Jody Garnett
> geomoose-psc mailing list
> geomoose-psc at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geomoose-psc
> Don’t ever wrestle with a pig. You’ll both get dirty, but the pig will
> enjoy it.
> —Cale Yarborough
URL: <http://lists.osgeo.org/pipermail/geomoose-psc/attachments/20171017/0c0de880/attachment.html>
More information about the geomoose-psc mailing list
