[Geomoose-users] Setting projection in GeoMoose
Jim Dahl jim.dahl at mail.co.douglas.mn.us
Fri Dec 7 16:31:50 EST 2007
Thanks for the reply, I must be confused with the terminology.  This is
what I want to do "to display the lat-lon coordinates in the status bar
and for passing lat-lon information into a service."
I do not want to reproject the data because it is native in County
Coords.  I want to do what Dakota has done -
http://gis.co.dakota.mn.us/geomoose/dak0.html .
thanks, jim
 -----Original Message-----
From: Johnson, Jeremy [mailto:JJohnson at ci.blaine.mn.us]
Sent: Friday, December 07, 2007 3:08 PM
To: Jim Dahl; geomoose-users at lists.sourceforge.net
Subject: RE: [Geomoose-users] Setting projection in GeoMoose
	If you read that a little closer, this has nothing to do with
displaying data from projections other than UTM-15.  I thought the same
thing too when I found the page.
	Projection support in GeoMOOSE is used to convert the coordinate
system of the map into lat-lon and back. This is only used to display
the lat-lon coordinates in the status bar and for passing lat-lon
information into a service. This does NOT re-project any images or data
that are retrieved from Mapserver or WMS services.
	From: geomoose-users-bounces at lists.sourceforge.net
[mailto:geomoose-users-bounces at lists.sourceforge.net] On Behalf Of Jim
Dahl
	Sent: Friday, December 07, 2007 3:06 PM
	To: geomoose-users at lists.sourceforge.net
	Subject: [Geomoose-users] Setting projection in GeoMoose
	After reading the how to :
http://www.geomoose.org:88/moose/documentation/how-tos/how-to-add-your-o
wn-projection
<http://www.geomoose.org:88/moose/documentation/how-tos/how-to-add-your-
own-projection>  I am still not sure what I have to do to set up my
interface to use County Projected data.  I see the MN county projections
are in the lib js file and the projection/MNcounty js file.  So that
must leave the configuration js file where there is just one reference
to UTM-15.  Is this something that is quick to do?
	Jim Dahl, GISP
	GIS Coordinator
	Douglas County Public Works
	509 3rd Ave W
	PO Box 398
	Alexandria MN 56308
	V 320-762-2933
	   320-763-6001
	F 320-763-7955
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20071207/f192dce9/attachment.html
More information about the Geomoose-users mailing list
