[Geomoose-users] tolerance on mouse click
Fischer, Brian bfischer at houstonengineeringinc.com
Sat Dec 8 22:09:20 EST 2007
I have not played around with this too much, but mine seems to honor my
tolerance settings.  I did notice it does adjust a bit when you zoom in.
Since the default tolerance units are pixels, you shouldn't need that
parameter.  Try leaving it out.  Also make sure your units in your
mapfile is set.  If you are still having problems, this would be a great
question for the Mapserver email list.  There are a lot more people on
that one that should be able to help out.
http://mapserver.gis.umn.edu/community/mailinglists/mapserver-users/
-Brian
From: geomoose-users-bounces at lists.sourceforge.net
[mailto:geomoose-users-bounces at lists.sourceforge.net] On Behalf Of Scott
Oatley
Sent: Thursday, December 06, 2007 5:32 PM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] tolerance on mouse click
I'm trying to use the "TOLERANCEUNITS pixel" setting in a mapfile to
support the identify tool. It doesn't seem to work. Rather than being a
consistent 10 pixels, for instance, it seems to vary with scale. Which
is what I'm trying to avoid my using pixels. Has anyone had success
using this with GeoMOOSE?
-Scott
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20071208/4f44bd74/attachment.html
More information about the Geomoose-users mailing list
