[Geomoose-users] Retireve XY
Jay Kapalczynski jkapalczynski at ci.maple-grove.mn.us
Tue Apr 1 09:05:00 EDT 2008
Right on....didnt think of that...obviously....
Yea I already have it returing XY but I do not have any geometry in the
ROW so I loose it then.....but makign a polygon over the entire county
would work...
THanks for the thoughts...
From: Fischer, Brian [mailto:bfischer at houstonengineeringinc.com]
Sent: Monday, March 31, 2008 8:49 PM
To: Jay Kapalczynski; geomoose-developers at lists.sourceforge.net;
geomoose-users at lists.sourceforge.net
Subject: RE: [Geomoose-users] Retireve XY
Yep, you could just create a dummy layer that is a big polygon that
covers your entire area and then use a copy of the identify service to
return the XY coordinate.  I think all you need to do is put [mapx]
[mapy] in your query template.  Also this mapserver reference guide
tells you everything you can have MapServer return in the template.
http://mapserver.gis.umn.edu/docs/reference/templatereference/referencem
anual-all-pages
-Brian
From: geomoose-users-bounces at lists.sourceforge.net
[mailto:geomoose-users-bounces at lists.sourceforge.net] On Behalf Of Jay
Kapalczynski
Sent: Friday, March 28, 2008 2:54 PM
To: geomoose-developers at lists.sourceforge.net;
Subject: [Geomoose-users] Retireve XY
Is there a way to modify the Select or Identify tool to not select or
identify layers but to only retieve the XY into the information tab?
RIght now the only way I can get the XY and open the information tab is
to use the identify or select.
And that is limited because I have to select a feature....what I want to
do is click anywhere in the map (on the aerials) and open the
Information Tab and return the XY
Any thoughts...
Can I modify the identify?
City of Maple Grove
Jason Kapalczynski
GIS / IS
Office 763.494.6282
Fax:   763.494.6419
<mailto:jkapalczynski at ci.maple-grove.mn.us>
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20080401/b647c724/attachment.html
More information about the Geomoose-users mailing list
