[Geomoose-users] [Geomoose-developers] PDF Printing & Mailing Labels.
Dan Little danlittle at yahoo.com
Mon Apr 14 09:19:23 EDT 2008
Two things:
1) Mailing Labels, et al, from Select was never intended to be supported.  This will be something we're looking into adding but there should be ZERO expectation with the current code for this to work.
2) It looks like the buffer select problem with PDF's is an issue with FPDF being configured properly.
----- Original Message ----
From: Jay Kapalczynski <jkapalczynski at ci.maple-grove.mn.us>
To: Nelson Soto <nellyfromma at gmail.com>; geomoose-users at lists.sourceforge.net; geomoose-developers at lists.sourceforge.net
Sent: Monday, April 14, 2008 8:12:24 AM
Subject: Re: [Geomoose-users] [Geomoose-developers] PDF Printing & Mailing Labels.
 _filtered {font-family:"Cambria Math";panose-1:2 4 5 3 5 4 6 3 2 4;}
 _filtered {font-family:Calibri;panose-1:2 15 5 2 2 2 4 3 2 4;}
 _filtered {font-family:Tahoma;panose-1:2 11 6 4 3 5 4 4 2 4;}
 _filtered {font-family:Consolas;panose-1:2 11 6 9 2 2 4 3 2 4;}
/* Style Definitions */
 p.MsoNormal, li.MsoNormal, div.MsoNormal
	{margin:0in;margin-bottom:.0001pt;font-size:11.0pt;font-family:"Calibri", "sans-serif";}
a:link, span.MsoHyperlink
	{color:blue;text-decoration:underline;}
a:visited, span.MsoHyperlinkFollowed
	{color:purple;text-decoration:underline;}
p.MsoPlainText, li.MsoPlainText, div.MsoPlainText
	{margin:0in;margin-bottom:.0001pt;font-size:10.5pt;font-family:Consolas;}
p.MsoAcetate, li.MsoAcetate, div.MsoAcetate
	{margin:0in;margin-bottom:.0001pt;font-size:8.0pt;font-family:"Tahoma", "sans-serif";}
span.PlainTextChar
	{font-family:Consolas;}
span.BalloonTextChar
	{font-family:"Tahoma", "sans-serif";}
.MsoChpDefault
 _filtered {margin:1.0in 1.0in 1.0in 1.0in;}
div.Section1
Nelson I am getting the same thing...getting a mix of
errors…
 I can only get one to actually work
 THere was some discussion a couple weeks ago and
 from what I understand Brian said there was going to be
some new release that covers this.
 This is what I am getting
 PDF Lables from Select:
 Fatal error: Failed to open shapefile
/ms4w/tmp/ms_tmp/[QUERY_ID]_buffered in
C:\ms4w\apps\GeoMOOSE\webdocs\php\mailing_labels.php on line 27
 PDF labels from Buffer Select
 Excel Lables from Select
 Fatal error: Failed to open shapefile/ms4w/tmp/ms_tmp/[QUERY_ID]_buffered in C:\ms4w\apps\GeoMOOSE\webdocs\php\mailing_labels.phpon line 27
 Excel Lables from Buffer
Select
 Everything works fine
 -----Original Message-----
From: geomoose-developers-bounces at lists.sourceforge.net[mailto:geomoose-developers-bounces at lists.sourceforge.net] On Behalf Of NelsonSoto
Sent: Monday, April 14, 2008 7:04 AM
To: geomoose-users at lists.sourceforge.net;geomoose-developers at lists.sourceforge.net
Subject: [Geomoose-developers] PDF Printing & Mailing Labels.
 I have searched the mailing lists and observed that these
functions
 require fpdf and python configured correctly. I am not
sure that I
 have them configured correctly, but they are installed.
When I click
 'PDF Labels" from the Select by Buffer tool, I get a
blank pdf page.
 To test if the function was working at all, I changed the
output tag
 to HTML and now receive a blank HTML page. What can I do
here to track
 down the culprit? Version of Python is 2.5.2. It's of
note that I
 receive no errors what so ever, just a blank page. If
more information
 is needed, please let me know.
 Thanks,
 Nelson
 This SF.net email is sponsored by the 2008 JavaOne(SM)Conference
 Don't miss this year's exciting event. There's still time
to save $100.
 Use priority code J8TL2D2.
 http://ad.doubleclick.net/clk;198757673;13503038;p?http://java.sun.com/javaone
 Geomoose-developers mailing list
 Geomoose-developers at lists.sourceforge.net
 https://lists.sourceforge.net/lists/listinfo/geomoose-developers
      ____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile.  Try it now.  http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
Skipped content of type multipart/related
More information about the Geomoose-users mailing list
