[Geomoose-users] Print.py help
Fischer, Brian bfischer at houstonengineeringinc.com
Mon Apr 14 10:18:38 EDT 2008
Nelson,
Actually MS4W 2.2.7 is compiled against Python 2.5.1.  Prior to 2.2.7 it
was using Python 2.4.4.
If you look in the MS4W folder you will find a "readme_install" file.
If you scroll down you will see a section called "Build Environments".
This tells you what version MS4W was compiled against for external
libraries.
I think to get the python .pdf printing to work you will need to have
python 2.5.1 installed.
Brian Fischer
Houston Engineering, Inc.
Maple Grove, MN
(763) 493-4522
From: geomoose-users-bounces at lists.sourceforge.net
[mailto:geomoose-users-bounces at lists.sourceforge.net] On Behalf Of Dan
Little
Sent: Monday, April 14, 2008 9:11 AM
To: Nelson Soto; geomoose-users at lists.sourceforge.net;
geomoose-developers at lists.sourceforge.net
Subject: Re: [Geomoose-users] Print.py help
MS4W uses 2.4.4 IIRC.
----- Original Message ----
To: geomoose-users at lists.sourceforge.net;
Sent: Monday, April 14, 2008 9:03:34 AM
Subject: [Geomoose-users] Print.py help
I am looking for help configuring Python. I have used 2.5.2 but
noticed perhaps that may be the wrong version to use based on what my
ms4w was compiled including? How do I determine the correct version of
Python to use? I have python.py in apache.cgi-bin as well as the php
folder. The error I get when attempting to print a map is the
following:
Internal Server Error
The server encountered an internal error or misconfiguration and was
unable to complete your request.
Please contact the server administrator, admin at local.domain and inform
them of the time the error occurred, and anything you might have done
that may have caused the error.
More information about this error may be available in the server error
log.
The error I receive from the error log from Apache is:
[Mon Apr 14 09:56:45 2008] [error] [client 127.0.0.1] (OS 3)The system
cannot find the path specified.  : couldn't create child process:
720003: print.py, referer: http://localhost/geomoose/test_demo.html
cannot find the path specified.  : couldn't spawn child process:
D:/ms4w/Apache/cgi-bin/print.py, referer:
This SF.net email is sponsored by the 2008 JavaOne(SM) Conference
Don't miss this year's exciting event. There's still time to save $100.
Use priority code J8TL2D2.
http://ad.doubleclick.net/clk;198757673;13503038;p?http://java.sun.com/j
avaone
Geomoose-users mailing list
Geomoose-users at lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20080414/0a985454/attachment.html
More information about the Geomoose-users mailing list
