[Geomoose-users] [Geomoose-developers] Print.py help
Jay Kapalczynski jkapalczynski at ci.maple-grove.mn.us
Mon Apr 14 12:17:22 EDT 2008
That was it...
Printing stops working if you install the new 2.5.2 version of Python...
Already ran through the install and config so that was done....just the
version of python that was messing things up
THanks Nelson
-----Original Message-----
From: Nelson Soto [mailto:nellyfromma at gmail.com]
Sent: Monday, April 14, 2008 10:42 AM
To: Jay Kapalczynski
Subject: Re: [Geomoose-developers] [Geomoose-users] Print.py help
Download python 2.5.1. not 2.5.2 or anything like that. then follow
these steps:
http://www.geomoose.org/moose/documentation/how-tos/how-to-install-and-c
onfigure-the-geomoose-print-service-with-the-ms4w-package
Moving certain files was the part  I had overlooked. If you can't find
them, run a search for them in the ms4w folder and sub folders and
they should come up. Let me know if this doesn't work.
On Mon, Apr 14, 2008 at 11:34 AM, Jay Kapalczynski
<jkapalczynski at ci.maple-grove.mn.us> wrote:
> What did you do to get the maps to print?
> Sent: Monday, April 14, 2008 10:03 AM
> Actually, it was both but I have gotten both resolved, more or less.
> From what I hear, I can't print a background image with print.py as
> there is some bug in it so it seems as if its worth just waiting for
> the php version anyways. have you  been able to get mailing labels and
> maps to print with any success? If not, maybe I can help now?
> On Mon, Apr 14, 2008 at 11:00 AM, Jay Kapalczynski
> > This is what I get when I try to print
> > From: geomoose-developers-bounces at lists.sourceforge.net
> > [mailto:geomoose-developers-bounces at lists.sourceforge.net] On Behalf
> Of
> > Nelson Soto
> > Sent: Monday, April 14, 2008 9:54 AM
> > To: geomoose-users at lists.sourceforge.net;
> > geomoose-developers at lists.sourceforge.net
> > Correction, I can use multiple layers, I receive this error when
> > attemptibng to include an ortho I'm displaying via GDAL as it is
using
> > a tiled index shape. Any thoughts on this?
> > On Mon, Apr 14, 2008 at 10:51 AM, Nelson Soto
<nellyfromma at gmail.com>
> wrote:
> > > Yes, I just did actually, thanks. However, I couldn't help but
> notice
> > > that you can only print the parcels layer? when printing more than
> one
> > > layer, the errors in my log are as follows:
> > > Mon Apr 14 10:49:48 2008] [error] [client 127.0.0.1] Premature end
> of
> > > script headers: print.py, referer:
> > > http://localhost/geomoose/test_demo.html
> > > [Mon Apr 14 10:49:48 2008] [error] [client 127.0.0.1] Traceback
> (most
> > > recent call last):\r, referer:
> > > [Mon Apr 14 10:49:48 2008] [error] [client 127.0.0.1]   File
> > > "D:/ms4w/Apache/cgi-bin/print.py", line 255, in <module>\r,
referer:
layer.data
> > > path+'/'+layer.data\r, referer:
> > > [Mon Apr 14 10:49:48 2008] [error] [client 127.0.0.1] TypeError:
> > > coercing to Unicode: need string or buffer, NoneType found\r,
> referer:
> > > [Mon Apr 14 10:49:55 2008] [error] [client 127.0.0.1] Premature
end
> of
> > > [Mon Apr 14 10:49:55 2008] [error] [client 127.0.0.1] Traceback
> (most
> > > [Mon Apr 14 10:49:55 2008] [error] [client 127.0.0.1]   File
referer:
layer.data
> > > [Mon Apr 14 10:49:55 2008] [error] [client 127.0.0.1] TypeError:
> referer:
> > > [Mon Apr 14 10:50:49 2008] [error] [client 127.0.0.1] Premature
end
> of
> > > [Mon Apr 14 10:50:49 2008] [error] [client 127.0.0.1] Traceback
> (most
> > > [Mon Apr 14 10:50:49 2008] [error] [client 127.0.0.1]   File
referer:
layer.data
> > > [Mon Apr 14 10:50:49 2008] [error] [client 127.0.0.1] TypeError:
> referer:
> > > On Mon, Apr 14, 2008 at 10:47 AM, Dan Little <danlittle at yahoo.com>
> wrote:
> > > > Jay, can you show the contents of your FPDF folder?
> > > > That might help folks.
> > > > ----- Original Message ----
> > > > From: Jay Kapalczynski <jkapalczynski at ci.maple-grove.mn.us>
> > > > To: Nelson Soto <nellyfromma at gmail.com>;
> > > > Sent: Monday, April 14, 2008 9:33:49 AM
> > > > Subject: Re: [Geomoose-users] [Geomoose-developers] Print.py
help
> > > > I follow the directions from the Geomoose site and my labels are
> workign
> > > > fine fro the Buffer select csv and pdf
> > > > Did you look at the directions on the Geomoose site under
> > documentation/how
> > > > tos
> > > > I just downloaded 2.5.2 python as well...
> > > > I verifyed the paths but no changes...
> > > > The only think I did was create a FPDF folder and place all
files
> from
> > the
> > > > download in there
> > > > It seems to work for me
> Behalf Of
> > > > Nelson Soto
> > > > Sent: Monday, April 14, 2008 9:04 AM
> > > > Subject: [Geomoose-developers] Print.py help
> > > > I am looking for help configuring Python. I have used 2.5.2 but
> > > > noticed perhaps that may be the wrong version to use based on
what
> my
> > > > ms4w was compiled including? How do I determine the correct
> version of
> > > > Python to use? I have python.py in apache.cgi-bin as well as the
> php
> > > > folder. The error I get when attempting to print a map is the
> > > > following:
> > > > Internal Server Error
> > > > The server encountered an internal error or misconfiguration and
> was
> > > > unable to complete your request.
> > > > Please contact the server administrator, admin at local.domain and
> inform
> > > > them of the time the error occurred, and anything you might have
> done
> > > > that may have caused the error.
> > > > More information about this error may be available in the server
> error
> > log.
> > > > The error I receive from the error log from Apache is:
> > > > [Mon Apr 14 09:56:45 2008] [error] [client 127.0.0.1] (OS 3)The
> system
> > > > cannot find the path specified.  : couldn't create child
process:
> > > > 720003: print.py, referer:
> system
> > > > cannot find the path specified.  : couldn't spawn child process:
> > > > D:/ms4w/Apache/cgi-bin/print.py, referer:
> > > > This SF.net email is sponsored by the 2008 JavaOne(SM)
Conference
> > > > Don't miss this year's exciting event. There's still time to
save
> $100.
> > > > Use priority code J8TL2D2.
http://ad.doubleclick.net/clk;198757673;13503038;p?http://java.sun.com/j
> avaone
> > > > _______________________________________________
> > > > Geomoose-developers mailing list
> > > > Geomoose-developers at lists.sourceforge.net
> > > > https://lists.sourceforge.net/lists/listinfo/geomoose-developers
> > This SF.net email is sponsored by the 2008 JavaOne(SM) Conference
> > Don't miss this year's exciting event. There's still time to save
> $100.
> avaone
More information about the Geomoose-users mailing list
