[Geomoose-users] Expressions
Jay Kapalczynski jkapalczynski at ci.maple-grove.mn.us
Tue Aug 19 17:39:13 EDT 2008
Like this?
                LAYER # Watermain_Pipe
                      #NAME Watermain_Pipe
                      DATA './watermain_pipes.shp'
                      STATUS DEFAULT
                      TYPE annotation
                    MAXSCALE 4000
                    MINSCALE 100
                    #LABELITEM 'DIAMETER'
                    LABELCACHE ON
                                 CLASSITEM "DIAMETER"
                                                CLASS
        LABEL
        EXPRESSION /[^6]/
        TYPE TRUETYPE
        FONT vera_sans
        ANGLE FOLLOW
        POSITION AUTO
        MAXSIZE 7
        SIZE 7
        MINSIZE 7
        ANTIALIAS TRUE
        COLOR 0 0 0
        #OUTLINECOLOR 255 255 192
        BUFFER 2
                                                END
                     END
From: Fischer, Brian [mailto:bfischer at houstonengineeringinc.com]
Sent: Tuesday, August 19, 2008 4:13 PM
To: Jay Kapalczynski; geomoose-users at lists.sourceforge.net; geomoose-developers at lists.sourceforge.net
Subject: RE: [Geomoose-users] Expressions
Yep, you just use a regular expression: /[^6]/
This is a mapserver syntax.
Brian Fischer
Houston Engineering, Inc.
Maple Grove, MN
(763) 493-4522
From: geomoose-users-bounces at lists.sourceforge.net [mailto:geomoose-users-bounces at lists.sourceforge.net] On Behalf Of Jay Kapalczynski
Sent: Tuesday, August 19, 2008 4:08 PM
To: 'geomoose-users at lists.sourceforge.net'; 'geomoose-developers at lists.sourceforge.net'
Subject: [Geomoose-users] Expressions
Is there a way to form a NOT statement in the expression...
To say for instance...show me all but EXPRESSION "6"
Instead of having to write each one out that you want....say I have pipe sizes 1-30 but 90% are 6 inches....jsut show the ones that are not 6 iches...
This should decrease the amount of labeling I have to do
                     CLASS
                                 LABEL
                                        EXPRESSION "12"
        TYPE TRUETYPE
        FONT vera_sans
        ANGLE FOLLOW
        POSITION AUTO
        MAXSIZE 7
        SIZE 7
        MINSIZE 7
        ANTIALIAS TRUE
        COLOR 0 0 0
        BUFFER 2
                                END
                     END
                     CLASS
                                LABEL
                                        EXPRESSION "16"
        TYPE TRUETYPE
        FONT vera_sans
        ANGLE FOLLOW
        POSITION AUTO
        MAXSIZE 7
        SIZE 7
        MINSIZE 7
        ANTIALIAS TRUE
        COLOR 0 0 0
        BUFFER 2
                                END
                     END
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20080819/6fe24dd1/attachment.html
More information about the Geomoose-users mailing list
