[Geomoose-users] Identify
Dan Little danlittle at yahoo.com
Mon Aug 25 16:16:16 EDT 2008
You can manually specify what layers you want identified if you want to ... you just need to change the "layers" input type to "user" and then passing in the layer names (from identify.map) that you want it to search.
----- Original Message ----
From: Jay Kapalczynski <jkapalczynski at ci.maple-grove.mn.us>
To: "geomoose-developers at lists.sourceforge.net" <geomoose-developers at lists.sourceforge.net>; "geomoose-users at lists.sourceforge.net" <geomoose-users at lists.sourceforge.net>
Sent: Monday, August 25, 2008 3:10:02 PM
Subject: [Geomoose-users] Identify
I am trying to create another identify button that will pull
and show all the fields from my layers.
I was wondering if it was possible to identify all the
layers even if they are not being displayed in the map.
Is there a setting or something I can bypass?
Thanks
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20080825/e6f51f17/attachment.html
More information about the Geomoose-users mailing list
