[Geomoose-users] Printing
Dan Little danlittle at yahoo.com
Wed Jan 9 11:41:47 EST 2008
Oh I've seen that one before, I just don't remember what the fix was... Brian do remember this one at all?
----- Original Message ----
From: Jay Kapalczynski <jkapalczynski at ci.maple-grove.mn.us>
To: Dan Little <danlittle at yahoo.com>; geomoose-developers at lists.sourceforge.net; geomoose-users at lists.sourceforge.net
Sent: Wednesday, January 9, 2008 10:14:24 AM
Subject: RE: [Geomoose-users] Printing
 _filtered {font-family:"Cambria Math";panose-1:2 4 5 3 5 4 6 3 2 4;}
 _filtered {font-family:Calibri;panose-1:2 15 5 2 2 2 4 3 2 4;}
 _filtered {font-family:Tahoma;panose-1:2 11 6 4 3 5 4 4 2 4;}
/* Style Definitions */
 p.MsoNormal, li.MsoNormal, div.MsoNormal
	{margin:0in;margin-bottom:.0001pt;font-size:11.0pt;font-family:"Calibri", "sans-serif";}
a:link, span.MsoHyperlink
	{color:blue;text-decoration:underline;}
a:visited, span.MsoHyperlinkFollowed
	{color:purple;text-decoration:underline;}
p.MsoAcetate, li.MsoAcetate, div.MsoAcetate
	{margin:0in;margin-bottom:.0001pt;font-size:8.0pt;font-family:"Tahoma", "sans-serif";}
p.MsoListParagraph, li.MsoListParagraph, div.MsoListParagraph
	{margin-top:0in;margin-right:0in;margin-bottom:0in;margin-left:.5in;margin-bottom:.0001pt;font-size:11.0pt;font-family:"Calibri", "sans-serif";}
span.BalloonTextChar
	{font-family:"Tahoma", "sans-serif";}
p.msochpdefault, li.msochpdefault, div.msochpdefault
	{margin-right:0in;margin-left:0in;font-size:10.0pt;font-family:"Times New Roman", "serif";}
span.balloontextchar0
span.balloontextchar00
span.emailstyle19
	{font-family:"Calibri", "sans-serif";color:windowtext;}
span.emailstyle20
	{font-family:"Calibri", "sans-serif";color:#1F497D;}
span.emailstyle21
span.emailstyle24
span.EmailStyle26
.MsoChpDefault
	{font-size:10.0pt;}
 _filtered {margin:1.0in 1.0in 1.0in 1.0in;}
div.Section1
 _filtered {}
 _filtered {}
ol
	{margin-bottom:0in;}
ul
Again sorry for the numberous
emails…
That was it…the PDF is now
being created…..I Created another folder and put the files there…maybe
for future reference the notes should read to create the folder or just change
the file so when Geomoose is loaded it dosent look for the FPDF folder rather
it just looks in the PDF folder….I don’t know just a thought.
ONE MORE thought/concern….
1.
I added a Parcel
Layer to my Geomoose Web Page.
2.
I then created
another seach option to search for PID value
3.
It then finds that
PID value and it zooms to it and highlights the parcel (everything is great)
When I print it highlights all
the Parcels Yellow in the PDF not just the one that I had searched for.
Is there something I am doing
wrong or is this a code thing?
THanks for your help Dan
GEOMOOSE
PDF PRINT
[mailto:danlittle at yahoo.com]
Sent: Wednesday, January 09, 2008 8:25 AM
To: Jay Kapalczynski; geomoose-developers at lists.sourceforge.net;
Subject: Re: [Geomoose-users] Printing
Sorry I missed the error in the litany of
emails.
To clarify, the "Mapbook" is the XML file that controls the vast
majority of the interface.  "statedemo.xml" is a Mapbook XML
file.
GeoMOOSE cannot find the FPDF library.  You have two options:
1) Open pdfPrint.php and change the variable to point to "." as the
location of FPDF.
2) Put the contents of the FPDF zip file into a folder named "fpdf"
(which is what the pdfPrint.php script is expecting).
./webdocs/php/pdfPrint.php
./webdocs/php/fpdf/* (all the stuff from the zip file)
Sent: Wednesday, January 9, 2008 8:16:08 AM
THanks for your response..it is
appreciated…..I showed the error below….below that you will see the
locations of the files that the error is pointing out….so it seems the
files are in the correct location.
I WAS A BIT CONFUSED ON step
7….I thought the mapbook XML file was in the statedemo.xml file…IS
THERE ANOTHER file I am missing?
it is telling me that a file is
not there? or something…but then the email…just below shows the
file (pdfPrint.php) in the correct location?
Confused….
I went to this location
http://www.geomoose.org/moose/documentation/how-tos/how-to-install-and-configure-the-geomoose-print-service-with-the-ms4w-package/?searchterm=print
went through the steps and then
printed and got an error
Was a bit confused at this step
What is the Mapbook XML
file…I thought the statedemo.xml contained the mapbook reference?
ERROR:
Sent: Wednesday, January 09, 2008 6:56 AM
Jay,
What is the error you are receiving?
To: geomoose-developers at lists.sourceforge.net;
Sent: Tuesday, January 8, 2008 4:33:15 PM
I am getting some files in the
temp folder so it is sort of working….
Just don’t know why its
not working entirely….
Thoughts?
This file does exist:
Sent: Tuesday, January 08, 2008 3:33 PM
To: 'geomoose-developers at lists.sourceforge.net';
'geomoose-users at lists.sourceforge.net'
Subject: RE: Printing
ERROR:
ANY
THOUGHTS?
THANKS
Sent: Tuesday, January 08, 2008 3:07 PM
Subject: Printing
I am getting to the point where I want to print from
Geomoose.
Is it possible to format a page and then simple add the
extent of the map to that formated page?
Where can I find some info on how to get this working?
THanks
Never
miss a thing. Make Yahoo your homepage.
Never
your homepage.
      ____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile.  Try it now.  http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
Skipped content of type multipart/related
More information about the Geomoose-users mailing list
