[Geomoose-users] redirect geomoose
Fischer, Brian bfischer at houstonengineeringinc.com
Thu Jan 10 12:07:56 EST 2008
You can set the service to display the results in a new window by
setting the display attribute for the services to window.  Should look
something like this:
<service title="Select Feature" default="true" locked="true"
cursor="url(cursors/select.cur), auto" shape="box" type="inspect-search"
display="window" icon="shared/images/toolbar/draw_polygon.jpg"
highlight="shared/images/toolbar/draw_polygon_selected.jpg">
       <url>php/select_countydemo.php</url>
       <input type="multipoint" name="coords"/>
       <input type="hidden" name="shape" value="poly"/>
       <input type="hidden" name="map"
value="/ms4w/apps/GeoMOOSE/maps_countydemo/select.map"/>
            LAYER_NAME:COLUMN_NAME to specify which query column to
return
           <input type="hidden" name="layer" value="Parcels:PIN"/>
           <input type="hidden" name="output" value="html"/>
   </service>
Brian Fischer
Houston Engineering, Inc.
Maple Grove, MN
(763) 493-4522
From: geomoose-users-bounces at lists.sourceforge.net
[mailto:geomoose-users-bounces at lists.sourceforge.net] On Behalf Of Vojko
Daneu
Sent: Tuesday, January 08, 2008 3:03 AM
To: GeoMOOSE
Subject: [Geomoose-users] redirect geomoose
Hallo there,
I want to use the "Select feature" service to redirect GeoMoose to a
different web-page. I start the service with the "Select feature" button
and clicking on a polygon of the map a java script file is executed that
opens a web-page in the same browser window. Instead of the new web-page
I get the error: >> The service "Select feature" did not return XML! <<.
Can somebody tell me, where to find the functions and code of the
"Select feature" service or how to solve this problem?
Thanks, best regards
Vojko
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20080110/a66458a1/attachment.html
More information about the Geomoose-users mailing list
