[Geomoose-users] [Geomoose-developers] Geodatabase
Fischer, Brian bfischer at houstonengineeringinc.com
Fri Jan 11 14:24:52 EST 2008
Jay,
In this case if you are using the MS4W package then the Personal
Geodatabase format option is already compiled into the OGR library so
you shouldn't have to worry about that.
Brian Fischer
Houston Engineering, Inc.
Maple Grove, MN
(763) 493-4522
-----Original Message-----
From: geomoose-users-bounces at lists.sourceforge.net
[mailto:geomoose-users-bounces at lists.sourceforge.net] On Behalf Of Bob
Basques
Sent: Friday, January 11, 2008 1:20 PM
To: Dan Little; geomoose-developers at lists.sourceforge.net;
geomoose-users at lists.sourceforge.net; Jay Kapalczynski
Subject: Re: [Geomoose-users] [Geomoose-developers] Geodatabase
Jay,
I don't know much about MapServer on windows, but this may be related to
how MapServer is Built.   The option for displaying a GeoDatabase may be
a particular option that needs to be compiled into MapServer when it's
built.
In Linux, you can check the MapServer config by running it on the
commandline, you sshould also be able to check the config (what things
it has been compiled to do, by running it from the Web as well.
You should check that the GeoDatabase option is present in the
MapServ.exe that you are using.   Take alook at the MapServer site to
see how this is done.
bobb
GISmo
GeoMOOSE
>>> "Jay Kapalczynski" <jkapalczynski at ci.maple-grove.mn.us> wrote:
I was a bit confused at this documentation.  This is what I have so
far..
HAS ANYONE placed a Geodatabase in their project.or can anyone help me
with what I have or don't have
This is the mapfile example they give..I seems that there is some code
that is missing above this code.I am referencing the shapefile mapfile I
have..
Has anyone out there placed a geodatabase In their Geomoose project?
I got on the MapServer email list and have not gotten a response back
yet..
THE Geodatabase shows up in the Map Layers Tab but will not show up in
the map
I think it should be as simple as:
Placing this in the Statedemo.xml
  <map title="StreetName" default="False">
<file>/ms4w/apps/GeoMOOSE/maps_statedemo/StreetNames/StreetName_8bit.map
</file>
  </map>
StreetName_8bit.map File
MAP
                NAME 'StreetName'
                SIZE 800 650
                STATUS ON
                EXTENT 189783.560000 4816309.330000 761653.524114
5472346.500000
                UNITS METERS
                FONTSET '../fonts/fontset.list'
                SYMBOLSET '../symbols/symbol.sym'
                TRANSPARENT TRUE
                IMAGETYPE PNG
                QUERYMAP
                                STATUS ON
                                STYLE SELECTED
                END
                WEB
                                  INCLUDE
"/ms4w/apps/GeoMOOSE/maps_statedemo/web_config.map"
                END
                LEGEND
                                                STATUS ON
                END
 LAYER
   NAME StreetName
   TYPE ANNOTATION
   CONNECTIONTYPE ogr
   CONNECTION "Streets.mdb"
   DATA "StreetName"
   STATUS ON
   CLASS
     NAME "StreetName"
     STYLE
       COLOR 255 255 120
     END
   END
 END
END ## end Map
THANKS
Sent: Thursday, January 10, 2008 10:10 AM
To: Jay Kapalczynski; geomoose-developers at lists.sourceforge.net;
Subject: Re: [Geomoose-users] Geodatabase
Hi Jay,
This is actually a Mapserver question.  I'd suggest contact the
mapserver user's list if you need more info, but here is the mapserver
documentation on how to use a Geodatabase:
http://mapserver.gis.umn.edu/docs/reference/vector_data/pgeo
-Duck
----- Original Message ----
From: Jay Kapalczynski <jkapalczynski at ci.maple-grove.mn.us>
To: geomoose-developers at lists.sourceforge.net;
Sent: Thursday, January 10, 2008 9:55:02 AM
Subject: [Geomoose-users] Geodatabase
Does GeoMooose support Geodatabase Annotation Feature Classes?
If so How would I go about adding it.How do I create a map fiel for it.
There are examples of using shapefiles but not Geodatabases.
Anyone know out there?
Thanks
Never miss a thing. Make Yahoo your homepage.
More information about the Geomoose-users mailing list
