[Geomoose-users] Multiple GEOMOOSE Installations
Fischer, Brian bfischer at houstonengineeringinc.com
Tue Jul 8 15:58:24 EDT 2008
Jeremy,
What I also do is just duplicate the config.js, geomoose.html,
mapbook.xml and menu.xml files and alter those.  Then I add the extra
shapefiles and mapfiles into the maps_xxx folder because that folder is
not web accessible anyway.  If I really want to keep things seperated
then I will duplicate the entire geomoose folder, but I am using IIS
with it so it is a little different then Apache conf.
-Brian
Brian Fischer
Houston Engineering, Inc.
Maple Grove, MN
(763) 493-4522
From: geomoose-users-bounces at lists.sourceforge.net
[mailto:geomoose-users-bounces at lists.sourceforge.net] On Behalf Of Dan
Little
Sent: Tuesday, July 08, 2008 2:25 PM
To: Johnson, Jeremy; geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] Multiple GEOMOOSE Installations
Hi Jeremy,
There's two parts to making this work.
Generally, I recommend people create a copy of the folder.
So your directory structure would have something like this:
webdocs_myapp1/geomoose.html
webdocs_myapp2/geomoose.html
And then change the apache httpd.conf appropriately.  Can you send us
the apache conf? It sounds like you might be a bit off there.
----- Original Message ----
From: "Johnson, Jeremy" <JJohnson at ci.blaine.mn.us>
To: geomoose-users at lists.sourceforge.net
Sent: Tuesday, July 8, 2008 9:31:51 AM
Subject: [Geomoose-users] Multiple GEOMOOSE Installations
I have a GEOMOOSE 1.2 application working and functioning on my PC for
testing.  I now want to create a second and a third application for
crime mapping and one for use only in our Emergency Operations Center.
Basically, what I did was copy the GEOMOOSE folder to the APPS directory
and renamed it to EOCWeb.  I created a new CONF file in the HTTPD.D
folder for the new website and made all of the necessary changes to the
files in webdocs.  I restarted teh Apache server and tried to open the
site, but I recieved a HTTP 403 Forbidden error.  Any thoughts on this?
Anyone else have any luck in created multiple GEOMOOSE sites?  Thank you
in advance.
Jeremy Johnson, GISP
G.I.S. Coordinator
City of Blaine
10801 Town Square Dr Ne
Blaine, MN  55449
(763) 717-2639
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20080708/2accb492/attachment.html
More information about the Geomoose-users mailing list
