[Geomoose-users] [Geomoose-developers] Retrieving Records from Database
Jay Kapalczynski jkapalczynski at ci.maple-grove.mn.us
Tue Jul 15 17:29:12 EDT 2008
I assume I have to add this as well in the ....demo.xml file
                                                <map
title="Parcel_Points_db" data="true" popups="true" default="True">
<file>/ms4w/apps/GeoMOOSE/Maple_Grove_GeoMoose/parcels/parcels_8bit.map<
/file>
                                                </map>
I know this is not correct...does anyone know how to modify the code
above to read a database....
Am I even on the right path?
Thanks
From: geomoose-developers-bounces at lists.sourceforge.net
[mailto:geomoose-developers-bounces at lists.sourceforge.net] On Behalf Of
Jay Kapalczynski
Sent: Tuesday, July 15, 2008 4:19 PM
To: geomoose-users at lists.sourceforge.net;
geomoose-developers at lists.sourceforge.net
Subject: [Geomoose-developers] Retrieving Records from Database
If I am using this code below to try and retrieve records from a
database:  Does anyone know how to format the Template.html....
Can what I am trying to do be done?
I have tried but am not having any luck returning the records from the
database.
This should simply show up in the Info Tab correct?
                LAYER
                                NAME 'Parcels'
                                CONNECTIONTYPE OGR
                                CONNECTION 'SomeDatabase.mdb'
                                DATA 'TableName'
                                STATUS ON
                                TYPE LINE
                                #TOLERANCEUNITS FEET
                                TOLERANCE 0.3
                                TEMPLATE 'SomeTemplate.html'
                END
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20080715/1bb69c95/attachment.html
More information about the Geomoose-users mailing list
