[Geomoose-users] GeoMoose error
Bob Basques Bob.Basques at ci.stpaul.mn.us
Fri Jul 25 23:20:11 EDT 2008
All,
Using 1.4, new install, pretty much stock too.  Got a problem with the requests not retrieving new images after navigating for a while.
Getting these error on a pretty much regular basis:  Basically the interface stops responding until the "Jump to" list is used, which seems to reset things.  I'm seeing this error regularly after navigating a few times, seem to occur after zooming in with the box zoom on most occasions.  The Wheel zooming also gets disabled in the process. Reloading the Browser session fixes things temporarily.
Note: if I use the Wheel mouse from the start of the session, seems to run a lot more reliably, haven't been able to freeze it up until using the Window drag zooming (a few times).  I don't know if this has anything to do with the problem, but the CURSORs don't seem to activate very fast when switching tools, could a lag in commands somehow be confusing the interface?
Here are the errors I'm seeing from FireBug.
layerUrl has no properties
loadLayerData("Electric SubStations")GeoMOOSE.js (line 663)
onNavigate()GeoMOOSE.js (line 665)
triggerEvent("navigate", NaN)GeoMOOSE.js (line 332)
changePointScale(NaN x=490094.0211083557 y=4978008.66851595 type=point, 3.1207468082796863, undefined, undefined)GeoMOOSE.js (line 339)
zoomToScaledImage()GeoMOOSE.js (line 518)
triggerMapRefresh(1)GeoMOOSE.js (line 523)
[Break on this error] function loadLayerData(id){var additionalInputs=new Array();var layerUrl=LayersT...
changePointScale(NaN x=491587 y=4976443 type=point, 14.4, undefined, undefined)GeoMOOSE.js (line 339)
changeView()GeoMOOSE.js (line 957)
More information about the Geomoose-users mailing list
