[Geomoose-users] Scale bar in metric
Fischer, Brian bfischer at houstonengineeringinc.com
Wed Jun 18 16:09:07 EDT 2008
It's in the scalebar.map file.  You will need to change the units in the
scalebar object to miles.  Also if you are using county coordinates make
sure you have units parameter under the map object set to feet.  The
ones that come with the demo are set to meters I believe.
-Brian
Brian Fischer
Houston Engineering, Inc.
Maple Grove, MN
(763) 493-4522
From: geomoose-users-bounces at lists.sourceforge.net
[mailto:geomoose-users-bounces at lists.sourceforge.net] On Behalf Of Jim
Dahl
Sent: Wednesday, June 18, 2008 2:59 PM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] Scale bar in metric
Where is the setting to change the scale bar to miles?  It is displaying
the right text but the scale is off by a factor of 3.28.
Thanks,
Jim Dahl, GISP
GIS Coordinator
Douglas County Public Works
509 3rd Ave W
PO Box 398
Alexandria MN 56308
V 320-762-2933
   320-763-6001
F 320-763-7955
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20080618/3aee6b55/attachment.html
More information about the Geomoose-users mailing list
