[Geomoose-users] multiple layer selection
Fischer, Brian bfischer at houstonengineeringinc.com
Fri Mar 14 11:08:19 EDT 2008
Lee,
Currently this is not possibly with GeoMOOSE.  I'm not sure it ever will
be...it seems like a custom feature.  It would also be hard to program
this to handle all situations.  With that said you could either try to
customize GeoMOOSE yourself or you could easily find a consultant that
could likely do this customization for a reasonable price.  Maybe the
cusomtization could be contributed back to the GeoMOOSE project.
Essentially you would have to write some of your own javascript code so
on the "OnChange" event of the dropdown would have it do something with
the other drop down.
On this note I think I am going to get GeoMOOSE so you can have an
active layer list in a drop down and use that to have users select which
layer is active and selectable.  This is different than how GeoMOOSE
currently handles users specifying which layer is selectable.
-Brian
Brian Fischer
Houston Engineering, Inc.
Maple Grove, MN
(763) 493-4522
From: geomoose-users-bounces at lists.sourceforge.net
[mailto:geomoose-users-bounces at lists.sourceforge.net] On Behalf Of Lee
Meilleur
Sent: Friday, March 14, 2008 9:52 AM
To: 'geomoose-users at lists.sourceforge.net'
Subject: [Geomoose-users] multiple layer selection
I saw Jay's post on being able to setup an additional layer to select
on.  Has anyone been able to setup multiple layers to select on?  I'd
like to have a pulldown with multiple layers.  As a layer is selected,
the Jump To options would change for the layer selected.  A non-working
example of what I'm trying to do can be viewed at:
http://www.gis.leg.mn/geomoose/atlas/
There's a Jump To Layer pulldown with multiple layers.  As a layer is
selected, the Jump To list would change accordingly.  Any ideas?
Thanks.
Lee Meilleur
LCC-GIS Office
Minnesota Legislature
100 Rev. Dr. MLK Jr Blvd.
55 State Office Building
St. Paul, MN 55155
651.296.0098  Fax: 651.297.3697
lee.meilleur at gis.leg.mn
http://www.gis.leg.mn <http://www.gis.leg.mn/>
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20080314/ea98d7d7/attachment.html
More information about the Geomoose-users mailing list
