[Geomoose-users] Custom Layer Not Loading
Fischer, Brian bfischer at houstonengineeringinc.com
Wed Mar 26 12:15:45 EDT 2008
That error is basically telling you MapServer can't find the your
mapfile.  Likely the path to that file is wrong or you have something
misspelled.  If you look in windows explorer what is your full path to
the file?  Is there a folder before the ms4w folder or is something
spelled wrong?  Something like C:/somefolder/ms4w/apps/GeoMOOSE.  If so
that could be your issue.  MS4W and GeoMOOSE expect the MS4W to be at
the root of a drive.
Also please cc the list so the answers to these questions can be found
by others in the future.
Thanks,
Brian
Brian Fischer
Houston Engineering, Inc.
Maple Grove, MN
(763) 493-4522
From: Clinton Olsen [mailto:clinton at co.emery.ut.us]
Sent: Wednesday, March 26, 2008 11:08 AM
To: Fischer, Brian
Subject: RE: [Geomoose-users] Custom Layer Not Loading
Brian,
Thanks for the suggestion.  Here is what I got when I used Firefox and
firebug.  When I tried to run the link below in a browser, I received
this message in the browser window: msLoadMap(): Unable to access file.
(/ms4w/apps/GeoMoose/MyMaps/roads.map)
http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apps/GeoMoose/MyMaps/road
s.map&mapext=1526238.5%207013167%202003498.5%207155757&mapsize=974%20291
&mode=map&MOOSETIME=1206547276515&layers=
Any ideas on where I should look now?
Clinton Olsen
Emery County
IS/GIS Technician
(435) 381-5281
	-----Original Message-----
	From: Fischer, Brian [mailto:bfischer at houstonengineeringinc.com]
	Sent: Tuesday, March 25, 2008 6:10 PM
	To: Clinton Olsen; geomoose-users at lists.sourceforge.net
	Hi Clinton,
	It could be a projection or path issue.  Can you use firefox and
firebug to look at the source of the image that is not loading for you?
Then you can take that URL and paste it into another browser window.
That should give you some hints as to why the layer is not loading.
Hopefully this makes sense, if not just say so and I can give some more
detailed instructions.
	-Brian
	From: geomoose-users-bounces at lists.sourceforge.net
[mailto:geomoose-users-bounces at lists.sourceforge.net] On Behalf Of
Clinton Olsen
	Sent: Tuesday, March 25, 2008 5:22 PM
	To: geomoose-users at lists.sourceforge.net
	Subject: [Geomoose-users] Custom Layer Not Loading
	I have several mapserver applications that I built using the
mapserver tutorial.  Now I am desirous to add more features to the
template, Geomoose has the features that I need.  I followed the
Geomoose tutorial, but when I brought the countydemo page, my shapefile
says it is loading but nothing ever comes up.  Anyone have any ideas on
how I can fix it?  Thanks.
	Clinton Olsen
	Emery County
	IS/GIS Technician
	(435) 381-5281
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20080326/c2706f3a/attachment.html
More information about the Geomoose-users mailing list
