[Geomoose-users] Button in Geomoose
Jay Kapalczynski jkapalczynski at ci.maple-grove.mn.us
Thu May 15 10:36:42 EDT 2008
I create the js file...pasted the function in it.
I use something like this to call a function
<p><input type="button" value="Click here" onclick="showAlert();"></p>
Do I have to specify the maplegrove.js file...cause the function is in
another file?
Appreciate the help....a little green with JavaScript...
Thanks Brian and Duck
Sent: Thursday, May 15, 2008 9:27 AM
To: Jay Kapalczynski; geomoose-developers at lists.sourceforge.net;
geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] Button in Geomoose
Hey Jay,
I've ran into this before with different browsers, occasionally they
don't take well to the addition of "script" tags in the document after
it's loaded.
In the config file there is a "CUSTOM_SCRIPTS" array which lists
javascript files that will be loaded on startup.  (I think this is fully
working, it was being used at Saint Paul.)
So I'd do something like this.
create a file called "maplegrove.js" which contains your function (which
I assume you later want to do more complex things).
maplegrove.js.
function alertSomeStuff(msg) {
    alert('This is your message:' + msg);
The next thing I would make sure you do is when defining the button to
make sure you use one of two conventions.
<!--- browsers sometimes get picky about onClick versus onclick, so try
to use the lower-case only version -->
<button onclick="alertSomeStuff('[PARCEL_ID]')">My Button</button>
or...
<!-- With inputs don't forget the ending "/>" -->
<input onclick="alertSomeStuff('[PARCEL_ID]')" value="My button value"/>
-Duck
----- Original Message ----
From: Jay Kapalczynski <jkapalczynski at ci.maple-grove.mn.us>
To: geomoose-developers at lists.sourceforge.net;
Sent: Thursday, May 15, 2008 9:13:29 AM
Subject: [Geomoose-users] Button in Geomoose
I am trying this:
This is on my Identify_Parcels.html
The button shows up in the tab after you do the idntify but nothing
happens when I click the actual button
Any thoughts?
<tr>
<td colspan="2"><b>Parcels Layer</b></td>
</tr>
<tr>
<td align="right">PID:</td>
<td>[PID]</td>
</tr>
<tr>
<td align="right">Address:</td>
<td>[ADDRESS]</td>
</tr>
<tr>
<td align="right">Assessing Sketches:</td>
<td><a href="pdf\Assessing_Sketches\[SKETCHES]"
target="_blank">[SKETCHES]</a></td>
</tr>
<script language="javascript" type="text/javascript">
function showAlert() {
 alert('This is an alert message!');
</script>
<p><input type="button" value="Click here" onClick="showAlert();"></p>
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20080515/d154c275/attachment.html
More information about the Geomoose-users mailing list
