[Geomoose-users] GeoMOOSE 1.4!
Fischer, Brian bfischer at houstonengineeringinc.com
Thu May 22 13:06:01 EDT 2008
Duck -
Great summary!  I got a little time this morning to post a change log
and migration tips page on the GeoMOOSE site.
http://www.geomoose.org/moose/moose/change-log
It's probably not complete, but a good start that we can add to.  I also
update the home page and the download link.  WE will need to work on
updating the reference guides and installation instructions over the
next week.  I will try to do as much as I can, but we are always looking
for volunteers to help out with the documentation.
-Brian
From: geomoose-users-bounces at lists.sourceforge.net
[mailto:geomoose-users-bounces at lists.sourceforge.net] On Behalf Of Dan
Little
Sent: Thursday, May 22, 2008 9:14 AM
To: GeoMOOSE Users List; geomoose-developers at lists.sourceforge.net
Subject: [Geomoose-users] GeoMOOSE 1.4!
GeoMOOSE 1.4 is now available for download!
Some of the very notable improvements include:
1) Buffered Select service now included with improvements to line, and
point feature selections.
2) Better support for relative paths.
3) Full Printing in PHP (No python required! Includes printing from WMS
services!)
4) Much improved startup code, making it much faster on load with no
more odd image flashing!
5) Popup/Maptips have improved modularity and predictability.
6) Image error handling has been drastically improved.  -- No more
obnoxious perpetual "Loading..." message when there is an error with one
of your images!!!
7) No more views in the mapbook! Views have been moved to the
configuration.js and are now included as a JSON object, making it
significantly easier to create multiple "Jump To:" zoom boxes.
8) New **VASTLY IMPROVED** Slider-Navigation Bar!
9) Re-written ReferenceMap now allows for a Fixed-view (traditional
ArcIMS style) or Dynamic Google-Maps style!
10) Client-side MIN/MAXSCALE settings are now enforced correctly!
11) We have completely revamped the directory structure to make more
seamless Linux/Windows updates.
Those who are upgrading from a 1.0 or 1.2 application, please download
this application to a new directory or make sure you backup your 1.0/1.2
application to a separate directory! There are some major changes to the
configuration.  This is not menat to be a complete summary guide! Brian
is working on something more complete, this highlights many of the major
configuration changes! Study the new configuration.js files closely
before performing a full upgrade!
1) Views.
    a) There are no more views in the MAPBOOK!!! "Views" have been moved
to the configuration.js file!  There are now two variables for storing
views, one stores the "initial" or "default" mapview, the other is used
to make the "Jump To" boxes.
       var INITIAL_VIEW = "X,Y,X,Y"; /* This is the new initial view
variable in the configuration.js */
    b) To create multiple "Jump To" boxes is now VERY easy by changing
the javascript variable "VIEWS".  For example, to create multiple drop
downs one could do the following:
    var VIEWS = {
            'Jump To:' : {
                    'Dakota County' :
'521238.614537864,4924218.86673578,473921.947801381,4974430.36885032',
                    'Parcel Data' :
'497205.409367,4923984.423582,477595.805945,4941970.52988'
            'Cities':" : {
                   'Apple Valley': "X,Y,X,Y",
                   'Rosemount' : "X,Y,X,Y"
2) If you want to use the print service please take a look at the
updated print service definition in the countydemo.xml mapbook.  You
will want to update your service to match.
3) *** You will need to update your "index.html" files. There is
significantly less javascript code in them and there has been many
updates to make this more friendly. ***
4) *** You default skin color may need to be changed by editing the
"index.html" file.  This is because of some updates to the Theme/Skin
manager.  There are two CSS  lines you will need to change:
11: <link href="skins/green/styles.css" rel="stylesheet" type="text/css"
id="theme-styles"/>
12: <link href="skins/green/menubar.css" rel="stylesheet"
type="text/css" id="theme-menu"/>
You will need to substitute "green" for whatever skin/theme you are
using.
5) Temporary directories are now configured in two places.  In the demo
all of the temporary directory information is now stored in
"temp_directory.map" which you can see in the "maps_countydemo" folder.
PHP scripts also need this information and it should be set in the
"php/Configuration.php" file.
6) If you find a layer is having issues with popups, edit its mapfile
and add the following:
    [snip]
    WEB
       QUERYFORMAT "text/xml"
    END
    [snip]
7) The slider settings have completely changed.  "configuration.js" line
156 has all the new settings.  Each step is pre-defined and you can
optionally name the step.
You might be asking yourself, "Is it worth all of the pain and suffering
to do the upgrade?"  The answer is a resounding, "Yes!" There are many,
many improvements to this version.
Download from SourceForge!
http://sourceforge.net/project/showfiles.php?group_id=160935&package_id=
181132&release_id=600465
As always, I'll be surfing the lists for any questions.  I'm also
available for hire if anyone would like me to come out a perform the
upgrade for you or provide some assistance.
-Duck
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20080522/515ad39e/attachment.html
More information about the Geomoose-users mailing list
