[Geomoose-users] Mailing labels Owner/Resident
Blaine Hackett blaine at gisrangers.com
Tue Nov 4 08:14:19 EST 2008
Brian
Would it be possible to edit the different select files so that when you
clicked on a parcel using the buffer instead of just having parcels in the
dropdown you could have parcel_owner and parcel_resident.  Then when it uses
the select.map file you have two different layers; one is called ParcelOwner
the other ParcelResident and those layers have a their own custom template
which either had the owner data or resident data.
Thoughts?
Blaine
  _____
From: Fischer, Brian [mailto:bfischer at houstonengineeringinc.com]
Sent: Monday, November 03, 2008 2:56 PM
To: Blaine Hackett; geomoose-users at lists.sourceforge.net
Subject: RE: [Geomoose-users] Mailing labels Owner/Resident
Blaine,
The only way to handle this would be to customize the mailing labels php
script with your own logic.  Unfortunately there would be no other way to
handle all the other logic people could come up with for mailing labels.
The only other way to handle this without doing any programming would be to
change your data so you always have something in a field for row one and on
the others they would be blank leaving a blank row on the label.
Brian Fischer
Houston Engineering, Inc.
Maple Grove, MN
(763) 493-4522
From: Blaine Hackett [mailto:blaine at gisrangers.com]
Sent: Monday, November 03, 2008 11:28 AM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] Mailing labels Owner/Resident
Hello
When creating mailing labels sometimes you want to send to the owner,
sometimes current resident and sometimes both.  I was wondering how other
people have implemented this with GeoMoose.
Thanks
Blaine
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20081104/95fc3e33/attachment.html
More information about the Geomoose-users mailing list
