[Geomoose-users] Special characters - "sh", "ch", "zh" - Central European symbols - part 2
Dan Little danlittle at yahoo.com
Tue Nov 4 10:31:37 EST 2008
Have you tried changing the encoding settings in the index.html file?
To: geomoose-users at lists.sourceforge.net
Sent: Tuesday, November 4, 2008 9:17:31 AM
Subject: Re: [Geomoose-users] Special characters - "sh", "ch", "zh" - Central European symbols - part 2
I was looking at MapScript which would be an
option, but due to the following fact I think that there must be an "easier"
solution maybe with some XML settings or something like that - when I
click on the "Identify" tool and the result is open in the div
"content_results_form" as a part of the GeoMoose window, the characters DO NOT
appear correctly. But when I get the direct link to the MapServer
call (vith FireBug) that is being called by Geomoose, e.g. "http://xxx.xxx.xxx.xxx/cgi-bin/mapserv?map=/home/webuser/identif.map&mapxy=468286.9195712629%20125082.02776175489&imgext=468282.0218372162%20125066.72580171067%20468308.97320987994%20125086.39975033894&layers=Boxes&imgsize=974%20711&mode=nquery"
in a separated window or a tab, those characters DO appear correctly. And also
when I set the charset of that window when the data is appearing correctly the
same charset as the GeoMoose window has, they look as they should.
That is the fact that is bothering me and I suspect
that some method which performs the "call" of the Mapserver from GeoMoose isn't
capable of getting data differently than in utf-8, but it proves that MapServer
is returning the data in the iso-8859.2 charset correctly.
Thank you in advance,
Matej Serc
matej at matnet.net
----- Original Message -----
To: Matej ; geomoose-users at lists.sourceforge.net
Sent: Monday, November 03, 2008 9:48  PM
Subject: RE: [Geomoose-users] Special  characters - "sh", "ch","zh" - Central European symbols - part 2
Matej,
I  think this would be a question for the mapserver mailing list.  I have  never used international characters so I have no experience with them.  I  wonder if it is an issue with the MapInfo format. I do know mapserver encodes  the attributes for HTML, but will leave them as is if you do something like  this:
[DBASE item name],[DBASE item name_esc],[DBASE item  name_raw]
Item  name from the attribute table of a queried layer. Only attributes for the  active query layers are accessible. Case must be the same as what is stored in  the DBASE file. ArcView, for example, uses all caps for shapefile field names.  Available only when processing query results.
By  default the attributes are encoded especially for HTML representation. In  addition the escaped version (for use in URLs) as well as the raw data is  available.
This  is from the mapserver website under the template reference guide  (http://mapserver.gis.umn.edu/docs/reference/templatereference/referencemanual-all-pages).   Maybe it won’t do this for MapInfo files.
Just  an idea,
Brian
Brian  Fischer
Houston  Engineering, Inc.
Maple  Grove, MN
(763)  493-4522
Sent: Monday, November 03, 2008 2:36  PM
Subject: [Geomoose-users] Special characters - "sh", "ch","zh" - Central European  symbols - part 2
I have been further  investigating this issue and I am out of ideas what to do. Let me explain  more. I have data with those symbols in a MapInfo (.TAB file has the entry  !charset WindowsLatin2 for charset definition). As I mentioned before,  MapServer returns correct data and when I open it in the different browser  everything is displayed as it should be.
But when the  results are open in the div inside geomoose, it is always (and I mean always)  displayed in utf-8 encoding. I have found out that it is typical behaveour for  setRequestHeader to always return data in utf-8. I tried adding  "charset=iso-8859-2" to those two setRequestHeader calls, but I get no  different results.
Now I don't know if  I should also write on the MapServer's mailing list if there is a chance to  convert the data from mode=nquery to specified encoding since I think that I  MUST get the results of the query in utf-8 from Mapserver otherwise this won't  work. But searching around, there is no option for that.
Maybe there is a  way of replacement some characters before displaying them?
Thank you for any  help in advance,
Matej  Serc
matej at matnet.net
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20081104/cb424eab/attachment.html
More information about the Geomoose-users mailing list
