[Geomoose-users] Print to PDF
Fischer, Brian bfischer at houstonengineeringinc.com
Thu Nov 6 10:45:48 EST 2008
Rick,
Your right I have never tried to print the DRGs.  Dan would know better
than I would what your options might be to get around this.  It might
involve code changes to print.php.
-Brian
From: Moore, Richard J [mailto:richard.moore at mnsu.edu]
Sent: Thursday, November 06, 2008 9:37 AM
To: Fischer, Brian; geomoose-users at lists.sourceforge.net
Subject: RE: [Geomoose-users] Print to PDF
Brian,
Thanks for the information.  I was able to create a configuration.php
and print.php file for each of the applications I have and then just
changed the reference to the print.php file in my application.xml file
in htdocs.
My other question now is;  I am trying to get the LMIC's USGS DRG's to
print but I get an error when I try that.  I have narrowed the culprit
down to the PrintWMS.map file in Resources.  The aerial photos from LMIC
come in as jpeg's and the printwms.map can handle because of the
reference to this image type("wms_format" "image/jpeg".  However, the
DRG's are sent from LMIC as PNG's.  The printwms.map cannot handle these
unless I change the "wms_format" to image/png.  When I do this then the
aerial photos don't print.
Is there a way to adjust the printwms.map file to accept both of these
formats from LMIC?  I would guess this would be a problem for everyone
trying to print these.  Although maybe a lot of people have not tried to
print out the drg's on a map.
I have included the printwms.map file for reference.
MAP
      LAYER
            NAME "wms_temp"
            TYPE RASTER
            STATUS DEFAULT
            CONNECTION "url"
            CONNECTIONTYPE WMS
            METADATA
                  "wms_srs" ""
                  "wms_name" ""
                  "wms_server_version" ""
            END
      END
END
Thanks,
Rick Moore
GIS Specialist
Water Resources Center
184 Trafton Science Center South
Minnesota State University, Mankato
Mankato, MN   56001
(507) 389-3267
From: Fischer, Brian [mailto:bfischer at houstonengineeringinc.com]
Sent: Wednesday, November 05, 2008 9:31 PM
To: Moore, Richard J; geomoose-users at lists.sourceforge.net
Rick,
This is one of the gotcha's with the demo's.  Currently there is only
one configuration.php file for both demo's.  I decided rather than
create the extra files I would need to get both working I would just
leave it working for the county demo.
If you want to get the printing working in both demo's you would need to
duplication the configuration.php and print.php files and change the
path in the configuration.php file to reference the state_demo
mapfiles.  Then change the include file in the print.php file to point
to the other configuration file (something like config_statedemo.php).
I don't have the files with me know but if you need an example I could
create one for you.
Hope this helps,
Brian
Sent: Wednesday, November 05, 2008 4:37 PM
To: 'geomoose-users at lists.sourceforge.net'
Subject: [Geomoose-users] Print to PDF
I am having problems with the Print to PDF in the State Demo example.
If I run the Print to PDF in the County Demo application it works
perfectly but when I try it in the State Demo application, I get this
error message.
Available Printing Formats:
Warning: [MapServer Error]: msLoadMap():
(/ms4w/apps/geomoose/maps_countydemo/./parks/parks_8bit.map) in
C:\ms4w\apps\GeoMOOSE\htdocs\php\print.php on line 177
Warning: Failed to open map file
/ms4w/apps/geomoose/maps_countydemo/./parks/parks_8bit.map in
Fatal error: Call to a member function setSize() on a non-object in
C:\ms4w\apps\GeoMOOSE\htdocs\php\print.php on line 178
It seems like it is referencing a path location to the county demo
application as show by the path.  I haven't been able to find a location
that states where to look for the files when it prints.
Any assistance would be helpful since it seems like it is a problem with
the State Demo application since the County demo works.  Also I do have
FPDF installed since the County Demo works for me.
Thanks,
Rick Moore
GIS Specialist
Mankato, MN   56001
(507) 389-3267
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20081106/8c6b7d11/attachment.html
More information about the Geomoose-users mailing list
