[Geomoose-users] PDF Printing - how to layer background
transparent?
Nils Zierath
nils.zierath at uni-bonn.de
Wed Nov 12 09:49:26 EST 2008
Dear Dan,
thanks for your response. Is there a workaround for transparent layers for now (other than
taking a screenshot)?
Thank you,
Nils
Dan Little schrieb:
> I'll have to look into this, I imagine it's because the Image is getting converted to RGB, then having transparency applied to it. The original "image stacking" code inside of the printing software was originally only tested against GIF and JPEG layers. We'll need to do some more work to make the 24-bit PNGs look good.
> ----- Original Message ----
>> From: CoFIS web | www.cofis.info <coffee at uni-bonn.de>
>> Cc: geomoose-users at lists.sourceforge.net
>> Sent: Wednesday, November 12, 2008 7:27:16 AM
>> Subject: [Geomoose-users] PDF Printing - how to layer background transparent?
>> Dear List,
>> this has been asked before - but I cannot find a sufficient answer for me.
>> I got the printing running in 1.6.1 but in the output I can only see the topmost
>> layer
>> with grey background/fill (same in html and pdf output). Forcing opacity on the
>> topmost
>> layer makes the lower one shine through. However, it looks by far not as good as
>> the
>> Geomoose map.
>> The layers I want to print are shapes on my local system. In my mapfile I
>> include the
>> following output format options:
>> NAME png
>> DRIVER 'GD/PNG'
>> MIMETYPE 'image/png'
>> IMAGEMODE RGBA
>> TRANSPARENT on
>> EXTENSION 'png'
>> The layer backgrounds appear transparently Firefox, IE7 and Safari on screen.
>> How can I
>> tell geomoose to do the same when printing?
>> Thank you,
>> Nils
>> Center for Development Research
>> Department of Ecology and Resource Management
>> Walter-Flex-Strasse 3
>> 53113 Bonn (Germany)
>> Tel.: +49 (0) 228 - 73-1793
>> FAX: +49 (0) 228 - 73-1889
>> E-Mail: coffee at uni-bonn.de
>> Web: http://www.cofis.info/atlas
>> http://www.coffee.uni-bonn.de
>> This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
>> Build the coolest Linux based applications with Moblin SDK & win great prizes
>> Grand prize is a trip for two to an Open Source event anywhere in the world
>> http://moblin-contest.org/redirect.php?banner_id=100&url=/
>> Geomoose-users mailing list
>> Geomoose-users at lists.sourceforge.net
>> https://lists.sourceforge.net/lists/listinfo/geomoose-users
Nils Zierath
E-Mail: nils.zierath at uni-bonn.de
Web: http://www.coffee.uni-bonn.de
http://www.zef.de
More information about the Geomoose-users
