[Geomoose-users] Gomoose map window scale not matching Mapserver scale (using MAXSCALEDENOM)
Nelson Soto NSoto at plotplans.com
Fri Nov 14 08:42:06 EST 2008
I think most are 72dpi.
-----Original Message-----
From: CoFIS web | www.cofis.info [mailto:coffee at uni-bonn.de]
Sent: Friday, November 14, 2008 8:33 AM
Cc: GeoMoose Mailing list
Subject: Re: [Geomoose-users] Gomoose map window scale not matching
Well, I found, that the first issue can be solved when increasing the
screen resolution
for distance calculation in the configuration.js from 72 to 96dpi (which
would correspond
to the resolution of my screen). Has anyone an idea what resolutions use
"most" screens -
72 or 96?
I assume, that the printing issue has got to do with
resolution-dependent scale
calculation when the images are being printed - just a guess.
Nils
CoFIS web | www.cofis.info schrieb:
> Hi folks,
> I realized that when using MAXSCALEDENOM for a layer in a mapfile,
Geomoose will not
> display this layer at the particular scale set, but only when zooming
in slightly more.
> EXAMPLE (applies to FF 3, IE is fine)
> a:
> in the mapfile		MAXSCALEDENOM 1,000,000
> map scale in Geomoose:	1:1,000,000
> Geomoose map window:	layer NOT shown
> b:
> in the mapfile		MAXSCALEDENOM 1,001,000
> map scale in Geomoose:	1,000,000
> Geomoose map window:	layer IS shown
> The equivalent applies to the printing function. Zooming in to a scale
where a layer with
> MAXSCALEDENOM set is being displayed GM will not print that particular
layer if the scale
> which has been set in the mapfile is too close to the current scale of
the map window. In
> comparison to the case above, the difference in the map window scale
and the scale set via
> MAXSCALEDENOM has to be larger in order to print the map (applies to
HTML & PDF printing
> output).
> EXAMPLE (tested with FF 3.0 and IE7)
> c:
> Printing result:	layer NOT printed
> EXAMPLE d:
> map scale in Geomoose:	1:900,000 (sometimes I even have to use
a larger scale)
> Printing result:	layer IS printed
> I assume that the printing issue is quite confusing for users and
would leave them with
> question marks in their eyes. Has anyone experienced that behavior?.
Is this a server-side
> or client-side problem?
> If it would help, I could post one of my mapfiles as well.
> Thanks for any suggestions,
> Nils
Center for Development Research
Department of Ecology and Resource Management
Walter-Flex-Strasse 3
53113 Bonn (Germany)
Tel.:   +49 (0) 228 - 73-1793
FAX:    +49 (0) 228 - 73-1889
E-Mail: coffee at uni-bonn.de
Web:    http://www.cofis.info/atlas
         http://www.coffee.uni-bonn.de
This SF.Net email is sponsored by the Moblin Your Move Developer's
challenge
Build the coolest Linux based applications with Moblin SDK & win great
prizes
Grand prize is a trip for two to an Open Source event anywhere in the
world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geomoose-users mailing list
Geomoose-users at lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users mailing list
