[Geomoose-users] Refresh Layers Automatically
Jay Kapalczynski
jkapalczynski at ci.maple-grove.mn.us
Mon Nov 17 12:58:46 EST 2008
Got it
Thanks Duck
Sent: Monday, November 17, 2008 11:53 AM
To: 'Dan Little'; 'geomoose-developers at lists.sourceforge.net'; 'geomoose-users at lists.sourceforge.net'
Subject: RE: [Geomoose-users] Refresh Layers Automatically
Can I do this?
function setIntervalNow()
//alert('Hello');
Events.triggerEvent('refreshlayer', 'Database');
Sent: Monday, November 17, 2008 11:50 AM
To: 'Dan Little'; geomoose-developers at lists.sourceforge.net; geomoose-users at lists.sourceforge.net
Thanks for the reply....nice foobar jab....
At one point I had something similar in there and it was calling this js pages function...
It was repeating the hello message every 5 seconds...
But I then got really confused how to call the refresh layer code from within the setIntervalNow function...
So what I need to do now, I am assuming is use the setInterval below which calls the function, which will run every 5 seconds as seen below. Once in the function I need to somehow call the RefreshLayer to refresh the database layer
command="Events.triggerEvent('refreshlayer', 'Database')
Any thoughts on how to trigger the refreshlayer? I assume that I have to trigger the refreshlayer as seen in the command above in a similar fashion....but now I am in a js page????
setIntervalNow();
setInterval("setIntervalNow()", 5000);
//TRIGGER THE 'Refreshlayer'
I have this in my html page so the connection the js page is there. I am getting the hello but just need to figure out how to trigger the 'refreshlayer'
<script type="text/javascript" src="lib/Start_Listening.js"></script>
Thanks Duck
Sent: Monday, November 17, 2008 10:23 AM
To: Jay Kapalczynski; geomoose-developers at lists.sourceforge.net; geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] Refresh Layers Automatically
Jay,
I can solidly say that you're off by a bit.
What you need to do in the command attribute is set it to call the function in StartListening.js, StartListening.js also needs to be included in your <head> ... </head> in the html page.
So, say you had a function called "foobar()" in Starting Listening.js, then the command attribute would be...
command="foobar()"
From: Jay Kapalczynski <jkapalczynski at ci.maple-grove.mn.us>
To: "geomoose-developers at lists.sourceforge.net" <geomoose-developers at lists.sourceforge.net>; "geomoose-users at lists.sourceforge.net" <geomoose-users at lists.sourceforge.net>
Sent: Monday, November 17, 2008 10:07:11 AM
Anyone with any thoughts on why I cant even get to the StartListening Function in the StartListening.js page from this call?
<service name="refreshLayers2" title="Refresh Layer every 5 Seconds" type="internal" default="true" locked="true" command="Events.triggerEvent('StartListening', 'DO I NEED SOMETHING HERE')" icon="shared/images/toolbar/MapleGrove_Buttons/Reload.jpg" highlight="shared/images/toolbar/MapleGrove_Buttons/Pictometry.jpg"/>
Thanks....
Sent: Wednesday, November 12, 2008 11:09 AM
To: geomoose-developers at lists.sourceforge.net; geomoose-users at lists.sourceforge.net
Have been talking with Duck and this is where I am right now....thought maybe someone else out there might have a few thoughts....
I created two buttons....one that will start refreshing a layer every couple seconds, one that will stop the refreshing.
I created two js pages that will handle the code
Am I on the right path here? Right now I cant even get to the Start_Listening.js page, so I know I am not doing something correct.
Demo.xml makes the calls to the js pages.
Js pages do the work....just not sure how to call the refreshlayer from js page
This works currently but I need it to repeat and refresh every few seconds
<service name="refreshLayers2" title="Refresh Layer" type="internal" default="true" locked="true" command="Events.triggerEvent('refreshlayer', 'Database')" icon="shared/images/toolbar/MapleGrove_Buttons/Reload.jpg" highlight="shared/images/toolbar/MapleGrove_Buttons/Pictometry.jpg"/>
THanks
3 FILES:
MapleGrove.demo.xml
<service name="refreshLayers3" title="Stop the refreshing" type="internal" default="true" locked="true" command="Events.triggerEvent('StopListening ', 'DO I NEED SOMETHING HERE')" icon="shared/images/toolbar/MapleGrove_Buttons/Reload.jpg" highlight="shared/images/toolbar/MapleGrove_Buttons/Pictometry.jpg"/>
StartListening.js
StartListening();
// Call the Events.triggerEvent('refreshlayer', 'Parcels');
alert('Hello');
Stop Listening.js
StopListening();
clearInterval("clearIntervalNow ()", 5000);
function clearIntervalNow ()
// clearInterval
alert('Hello');
Sent: Tuesday, November 11, 2008 9:25 AM
Do a google search on setTimeout and setInterval, they aren't built-in to GeoMOOSE, they're native JS functions.
To: Dan Little <danlittle at yahoo.com>
Sent: Monday, November 10, 2008 3:02:38 PM
I did a search in all the .js files, the main config, demos, and menu files and cant find a ... function setTimeout ()
Any thoughts as to where they are?
I suppose then I can just call the function and run the refresh code against the settimeout and set interval code (somehow)
Will cross that bridge when I get to it. For now just cant seem to find the functions....
VERY APPRECITED duck....
Sent: Monday, November 10, 2008 2:44 PM
Jay,
You'll need to look into setTimeout or setInterval Javascript functions. You'll then need to write a couple of wrapper functions and attach that to two different buttons (easy to do with a service).
To: Dan Little <danlittle at yahoo.com>; "geomoose-developers at lists.sourceforge.net" <geomoose-developers at lists.sourceforge.net>; "geomoose-users at lists.sourceforge.net" <geomoose-users at lists.sourceforge.net>
Sent: Monday, November 10, 2008 2:28:16 PM
That works great....but I am trying to do something else. Hoping you can point me in the correct direction.
Was trying to get my hands on the code and modify it in another file. I want to click a button in the tool bar and it runs the refresh on a particular layer every 10 seconds (or some other specified time value)
So I would need a loop to run then stop when the another button was clicked.
Any thoughts?
Sent: Monday, November 10, 2008 2:16 PM
Example:
One Layer - Events.triggerEvent('refreshlayer', 'Parcels');
All Layers - Events.triggerEvent('refreshlayers', '');
Sent: Monday, November 10, 2008 2:09:48 PM
Subject: [Geomoose-users] Refresh Layers
Where is the function that refreshes the layers?
Anyone out there know how I could configure the code the refresh a specific layer?
Thanks
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20081117/69837b37/attachment.html
More information about the Geomoose-users
