[Geomoose-users] GeoMoose layer loading.
Nelson Soto NSoto at plotplans.com
Thu Nov 20 10:19:29 EST 2008
Very helpful, thanks. I'm looking forward to checking that out.
From: Fischer, Brian [mailto:bfischer at houstonengineeringinc.com]
Sent: Wednesday, November 19, 2008 4:50 PM
To: Nelson Soto; geomoose-users at lists.sourceforge.net
Subject: RE: [Geomoose-users] GeoMoose layer loading.
Nelson,
This has been something I have wanted for a while now.  The problem is
with the current mapbook structure in GeoMOOSE 1.x serious it would be
very tough to do.
We have addressed this in the GM2 concept and will be possible at this
version.  You will also be able to mix and match groupings of layers
into images.  For example you could have aerials be one image, all your
basemap data be another image and parcels be an image.  You would still
be able to toggle on and off any image you want in the list.
Hope this helps,
Brian
Sent: Wednesday, November 19, 2008 9:53 AM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] GeoMoose layer loading.
This is kind of out there, but let's say a user doesn't like the
'layer-by-layer' loading that takes place when a new map is drawn. For
instance, you see each layer render one at a time when zooming in and
out. Is there currently any way to toggle the render behavior so that
perhaps you only see the map once it has completely drawn?
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20081120/de8aeaf3/attachment.html
More information about the Geomoose-users mailing list
