[Geomoose-users] [Geomoose-developers] GeoMoose 1.6 IE7 Bug
Dan Little danlittle at yahoo.com
Tue Oct 7 10:53:14 EDT 2008
It will be a minor file fix if you're already at 1.6.  All you should need to swap out is GeoMOOSE.js and main.js.
----- Original Message ----
From: Jay Kapalczynski <jkapalczynski at ci.maple-grove.mn.us>
To: "Fischer, Brian" <bfischer at houstonengineeringinc.com>; Dan Little <danlittle at yahoo.com>; Nelson Soto <NSoto at plotplans.com>; "geomoose-users at lists.sourceforge.net" <geomoose-users at lists.sourceforge.net>; "geomoose-developers at lists.sourceforge.net" <geomoose-developers at lists.sourceforge.net>
Sent: Tuesday, October 7, 2008 9:46:43 AM
Subject: RE: [Geomoose-developers] [Geomoose-users] GeoMoose 1.6 IE7 Bug
Thanks….I was not sure if that was the same one…..
What kind of time frame?
Is it going to be just a file that we replace of are we going to
have to replace a bunch of files….
Again just don’t want to rewrite my code…
Thanks for all your help guys….
Might have a few questions with the new folder and file format
in v1.6….but sure I will be able to track them down….
[mailto:bfischer at houstonengineeringinc.com]
Sent: Tuesday, October 07, 2008 9:43 AM
To: Jay Kapalczynski; Dan Little; Nelson Soto;
geomoose-users at lists.sourceforge.net; geomoose-developers at lists.sourceforge.net
You found the known bug.  Dan is working on a fix and when
it is fixed we will release a 1.6.1 version.
[mailto:jkapalczynski at ci.maple-grove.mn.us]
Sent: Tuesday, October 07, 2008 9:41 AM
To: Fischer, Brian; Dan Little; Nelson Soto; geomoose-users at lists.sourceforge.net;
I just installed v1.6 with the latest version of Map Server.
When I open the test apps in IE no tool bar buttons show up
Its fine in Firefox…
Thoughts….
Sent: Wednesday, September 24, 2008 8:34 AM
To: Dan Little; Nelson Soto; geomoose-users at lists.sourceforge.net;
Subject: Re: [Geomoose-developers] [Geomoose-users] GeoMoose 1.6 IE7 Bug
No, it’s probably before you fixed that bug.  After you get
the latest code changes into trunk I will package up a 1.6.1 version.
If anyone else finds any bugs, let us know and we might be able
to address them in a 1.6.1 version.
Thanks,
Brian
Brian Fischer
Houston Engineering, Inc.
Maple Grove, MN
(763) 493-4522
Sent: Wednesday, September 24, 2008 7:55 AM
To: Nelson Soto; geomoose-users at lists.sourceforge.net;
Brian,
Is 1.6 operating off of the latest code in Trunk? This was a bug that was fixed
for the MMCD application.
To: geomoose-users at lists.sourceforge.net;
Sent: Wednesday, September 24, 2008 7:52:11 AM
Subject: [Geomoose-users] GeoMoose 1.6 IE7 Bug
After extracting the new version and checking
out the demos, neither pulls up their toolbar under IE7 and I get an e
Javascript error on line 692. Likely the error is somewhere before hand or as a
result of something else because line 692 is ʽhttp.send(postData);}ʼ
Itʼs worth noting that Firefox 3 works
correctly so far.
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20081007/8840a2aa/attachment.html
More information about the Geomoose-users mailing list
