[Geomoose-users] roads layer is not transparent in IE6 AGG renderer
Mark Volz MarkVolz at co.lyon.mn.us
Tue Oct 14 11:57:37 EDT 2008
When using IE6 as a client it appears that my roads layer is not transparent,
Instead I see a gray background under my roads.  I am using AGG as a rendered
for roads.  Is this a problem with IE 6, a bug with AGG, or could something
be incorrect with my .map file?
Also,
A while ago I noticed that when using the AGG reindeer the legend text does
not display.  Has anyone found a workaround for this?  Has it been fixed in
1.6 (I haven't tried 1.6 yet).
Thanks
MAP
            NAME 'roads'
            SIZE 800 650
            STATUS ON
            UNITS FEET
            Projection  #Lyon County Coordinates
            "proj=lcc"
                        'lat_1=44.25'
                        'lat_2=44.58333333333334'
                        'lat_0=44.19555555555555'
                        'lon_0=-95.85000000000001'
                        'x_0=152400.3048006096'
                        'y_0=30480.06096012192'
                        'a=6378559.758'
                        'b=6357173.65471281'
                        "units=ft"
            "no_defs"
            END #projection
            FONTSET '../fonts/fontset.list'
            SYMBOLSET '../symbols/symbol.sym'
            TRANSPARENT TRUE
            #IMAGETYPE PNG
            #IMAGETYPE PNG #STANDARD OUTPUT TO PNG
            ##########ATTEMPT TO HOOK INTO AGG RENDERER
            OUTPUTFORMAT
                        NAME 'AGG_PNG24'
                        DRIVER AGG/PNG
                        IMAGEMODE RGB
            END #HOOK TO AGG RENDERER
            QUERYMAP
                        STATUS ON
                        STYLE SELECTED
            END
            WEB
                          INCLUDE
"/ms4w/apps/GeoMOOSE/maps_lyondemo/web_config.map"
            END
            LEGEND
                        STATUS ON
            END
            LAYER
MAP
            NAME 'roads'
            SIZE 800 650
            STATUS ON
            UNITS FEET
            END #projection
            TRANSPARENT TRUE
            #IMAGETYPE PNG
            OUTPUTFORMAT
                        NAME 'AGG_PNG24'
                        DRIVER AGG/PNG
                        IMAGEMODE RGB
            QUERYMAP
                        STATUS ON
                        STYLE SELECTED
            END
            WEB
                          INCLUDE
            END
            LEGEND
                        STATUS ON
            END
            LAYER
Mark Volz
GIS Specialist
Lyon County, MN
(507) 532-8218
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20081014/998e093a/attachment.html
More information about the Geomoose-users mailing list
