[Geomoose-users] GeoMoose Services and output options.
Dan Little danlittle at yahoo.com
Wed Oct 29 09:25:54 EDT 2008
They don't need to be used.  GeoMOOSE will handle whatever return type you throw at it.
The XML mode was originally the only return type GeoMOOSE supported.  There are provisions in that return type to return HTML-like tables in XML.  Folks found this not flexible enough so the HTML, text, and CSV formats were added.
To: geomoose-developers at lists.sourceforge.net; geomoose-users at lists.sourceforge.net
Sent: Wednesday, October 29, 2008 7:33:46 AM
Subject: [Geomoose-users] GeoMoose Services and output options.
I have done some work for my own services and naturally have
noticed there are typically xml and html output modes. I understand why the
html exists, but I am curious if the XML ever gets used? For instance, if I
modify the output of the HTML, should I also be replicating these edits for the
XML output as well? If so, when do these get used?
Thanks.
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20081029/01264b81/attachment.html
More information about the Geomoose-users mailing list
