[Geomoose-users] Search based on lat/lon layer
Jim Klassen Jim.Klassen at ci.stpaul.mn.us
Fri Apr 24 18:16:27 EDT 2009
Two thoughts.
1) There have been recent changes to shpext and some of the other related tags in mapserver templates that support supplying an output projection. (or at least transforming them to the mapfiles output projection).... that reminds me I need to make a ticket for one of those changes.
http://trac.osgeo.org/mapserver/ticket/2961
Anyway... I already did that.
--- maptemplate.c	(revision 8844)
+++ maptemplate.c	(working copy)
@@ -3282,14 +3282,23 @@
-    sprintf(repstr, "%f %f", (mapserv->resultshape.bounds.maxx + mapserv->resultshape.bounds.minx)/2, (mapserv->resultshape.bounds.maxy + mapserv->resultshape.bounds.miny)/2);
-    outstr = msReplaceSubstring(outstr, "[shpmid]", repstr);
-    sprintf(repstr, "%f", (mapserv->resultshape.bounds.maxx + mapserv->resultshape.bounds.minx)/2);
-    outstr = msReplaceSubstring(outstr, "[shpmidx]", repstr);
-    sprintf(repstr, "%f", (mapserv->resultshape.bounds.maxy + mapserv->resultshape.bounds.miny)/2);
-    outstr = msReplaceSubstring(outstr, "[shpmidy]", repstr);
+	    rectObj tempExtent;
+	    tempExtent.minx = mapserv->resultshape.bounds.minx;
+	    tempExtent.maxx = mapserv->resultshape.bounds.maxx;
+	    tempExtent.miny = mapserv->resultshape.bounds.miny;
+	    tempExtent.maxy = mapserv->resultshape.bounds.maxy;
+	    if(msProjectionsDiffer(&(mapserv->resultlayer->projection), &(mapserv->map->projection)))
+ 	        msProjectRect(&(mapserv->resultlayer->projection), &mapserv->map->projection, &tempExtent);
+	    sprintf(repstr, "%f %f", (mapserv->resultshape.bounds.maxx + mapserv->resultshape.bounds.minx)/2, (mapserv->resultshape.bounds.maxy + mapserv->resultshape.bounds.miny)/2);
+	    outstr = msReplaceSubstring(outstr, "[shpmid]", repstr);
+	    sprintf(repstr, "%f", (tempExtent.maxx + tempExtent.minx)/2);
+	    outstr = msReplaceSubstring(outstr, "[shpmidx]", repstr);
+	    sprintf(repstr, "%f", (tempExtent.maxy + tempExtent.miny)/2);
+	    outstr = msReplaceSubstring(outstr, "[shpmidy]", repstr);
     if(processExtentTag(mapserv, &outstr, "shpext", &(mapserv->resultshape.bounds), &(mapserv->resultlayer->projection)) != MS_SUCCESS)
       return(NULL);
     if(processExtentTag(mapserv, &outstr, "shpext_esc", &(mapserv->resultshape.bounds), &(mapserv->resultlayer->projection)) != MS_SUCCESS) /* depricated */
2) You can reproject using the OpenLayers code: Something along the lines of: coord = {'x': x_coord, 'y': y_coord}; OpenLayers.Projection.transform({'x': lon, 'y': lat}, <insert your projection here>, LatLongProjection); ll = {'lon': coord.x, 'lat': coord.y} ; Map.panTo(ll);
(From memory, check the projection call from geomoose/main.js)
>>> Brent Fraser <bfraser at geoanalytic.com> 04/24/09 4:32 PM >>>
  I've got a layer in geographic coordinates I'd like to do a GeoMoose Search on.  Unfortunately, Mapserver's shpminx/shpmaxx/shpminx/shpmaxx template values return the shape extents in the layer's coordinate system, not the map coordinate system, so the GeoMoose Map.zoomToViewString call in the itemquery template does not work.
  Has anyone got a Map.zoomToLatLonViewString function laying around?
My other options are:
  Convert the layer to the map projection (a maintenance nightmare)
  Enhance Mapserver's [shpmin} handling to match it's [shpext proj=] abilities (too much work right now)
Thanks!
Brent Fraser
Crystal Reports - New Free Runtime and 30 Day Trial
Check out the new simplified licensign option that enables unlimited
royalty-free distribution of the report engine for externally facing
server and web deployment.
http://p.sf.net/sfu/businessobjects
Geomoose-users mailing list
Geomoose-users at lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users mailing list
