[Geomoose-users] select function returns duplicate records
Len Kne lkne at houstoneng.com
Wed Dec 2 08:55:54 EST 2009
Does your mapfile also have a TEMPLATE tag?  That would give a second response.
Len
From: Devon Piernot [mailto:piernotd at uwplatt.edu]
Sent: Tuesday, December 01, 2009 4:41 PM
To: geomoose-users
Subject: [Geomoose-users] select function returns duplicate records
Hey all,
When selecting any layer in my demo application (2.0.l), the results tab displays the correct number of found shapes, but it also produces duplicate html records.  I've attached a screen shot as an example.  I haven't really played with the select.php code so I think the problem must be with my mapbook or the individual mapfiles, but I can't see anything wrong with them.
Here is an example of the METADATA heading in one of these mapfiles:
    METADATA
        'identify_record' 'identify_zoning.html'
        'select_record'   'select_zoning.html'
        'select_header'   'select_header.html'
        'itemquery'       'itemquery_zone.html'
        'itemquery-filter' '/.*[qstring].*/i'
        'qstring_validation_pattern' '.'
        'feature_report' 'parcel.xml'
    END
    TOLERANCE 0
Has anyone experienced a similar problem? Any ideas?
Thanks
Devon Piernot
GIS / Web Developer
Southwestern Wisconsin Regional Planning Commission
(608) 342-6065
piernotd at uwplatt.edu<mailto:piernotd at uwplatt.edu>
www.swwrpc.org<http://www.swwrpc.org>
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20091202/46896208/attachment.html
More information about the Geomoose-users mailing list
