[Geomoose-users] creating a new project
CoFIS Web coffee at uni-bonn.de
Thu Dec 3 09:42:38 EST 2009
I think you should check if the GM2 folder is accessible at all.
Does your URL match the path in your web directory.
Does your webserver have access rights to the new GM2 directory?
Nils
jefe rodolfo pereira da silva schrieb:
> Hi Nils,
> I was try to update this file but the problem is continue... Error: 404
> not found.
> Thanks for you attention.
> 2009/12/3 CoFIS Web <coffee at uni-bonn.de <mailto:coffee at uni-bonn.de>>
>     Jefe,
>     you mean if you access http://yourdomain.com/new-gm2-directory
>     nothing happens - no errors?
>     If your mapfile directory lives outside the gm directory, have you
>     updated the mapfile-dir-path in settings.ini and mapbook.xml?
>     Nils
>         Hi,
>         I was copy geomoose2 directory and rename with other name, but
>         not run.. Some tips to do it?
>         Jefe Rodolfo Silva
>         Analista de SIG
>         (65) 3301-2426
>         http://189.59.94.5/consis.html
>         Join us December 9, 2009 for the Red Hat Virtual Experience,
>         a free event focused on virtualization and cloud computing.
>         Attend in-depth sessions from your desk. Your couch. Anywhere.
>         http://p.sf.net/sfu/redhat-sfdev2dev
>         _______________________________________________
>         Geomoose-users mailing list
>         Geomoose-users at lists.sourceforge.net
>         <mailto:Geomoose-users at lists.sourceforge.net>
>         https://lists.sourceforge.net/lists/listinfo/geomoose-users
>     Center for Development Research
>     Department of Ecology and Resource Management
>     Walter-Flex-Strasse 3
>     53113 Bonn (Germany)
>     Tel.:   +49 (0) 228 - 73-1793
>     FAX:    +49 (0) 228 - 73-1889
>     E-Mail: coffee at uni-bonn.de <mailto:coffee at uni-bonn.de>
>     Web:    http://www.cofis.info/atlas
>            http://www.coffee.uni-bonn.de
> Jefe Rodolfo Silva
> Analista de SIG
> (65) 3301-2426
More information about the Geomoose-users mailing list
