[Geomoose-users] NASA OnEarth wms
Moore, Richard J richard.moore at mnsu.edu
Thu Dec 10 10:49:57 EST 2009
Going by your suggestion 2, I think that would be the easiest.  In GM 1.6, I had my USGS color relief using a .map file and referencing it in the mapbook.xml.  Here is what I had.  Do I need to make any changes to it and what would the map-source look like in the mapbook.  I have included what I thought would work.
<map-source name="eros" type="mapserver">
	<file>./data/wms/eros.map</file>
	<layer name="eros"/>
</map-source>
MAP
  NAME 'eros'
  SIZE 800 650
  STATUS ON
  EXTENT 189783.560000 4816309.330000 761653.524114 5472346.500000
  UNITS METERS
  IMAGETYPE JPEG
  TRANSPARENT TRUE
	WEB
		INCLUDE "../temp_directory.map"
	END
  PROJECTION
    'init=epsg:26915'
  END
  LAYER
    NAME         eros
    TYPE         RASTER
    #OFFSITE      0 0 0
    STATUS       DEFAULT
    CONNECTIONTYPE WMS
    CONNECTION "http://imsref.cr.usgs.gov:80/wmsconnector/com.esri.wms.Esrimap/USGS_EDC_National_Atlas?"
    METADATA
      "wms_srs" "EPSG:4326"
      "wms_name" "ATLAS_200M_COLOR_RELIEF_48"
      "wms_server_version" "1.1.1"
      "wms_format" "image/png"
      "wms_styles" ""
      "wms_exceptions" "application/vnd.ogc.se_inimage"
    END
    PROJECTION
      "init=epsg:4326"
    END
  END
END
-----Original Message-----
From: Brent Fraser [mailto:bfraser at geoanalytic.com]
Sent: Thursday, December 10, 2009 9:12 AM
To: Moore, Richard J
Cc: 'Devon Piernot'; geomoose-users
Subject: Re: [Geomoose-users] NASA OnEarth wms
This is to be expected (I think).  The providers of the various WMS servers
decide on which Spatial reference systems their data will be served in (usually
one or two).  If it is not an SRS you like, with most browser-based WMS clients
you cannot use the data.
   With GeoMoose v2, Dan made an enhancement to warp the imagery from the WMS
server SRS to the SRS you've selected in GeoMoose.  A simple warp is not a
rigorous map projection, so the farther you zoom out the worst the warp
approximation is.
Possible solutions:
   1. Set up your GeoMoose site to use the same SRS as the WMS servers (4326? yuck!)
   2. Pass the WMS stream through Mapserver to re-project it (use Mapserver as a
WMS client, then serve it up to GeoMoose).
   3. Serve the data yourself: Dowload the Landsat data from
http://hypersphere.telascience.org/onearth/.  Then combine the bands for natural
color, fuse the pan band to increase the resolution from 30m to 15m, then do
some color adjusting (yikes!).
Best Regards,
Brent Fraser
Moore, Richard J wrote:
> Hello all,
> I want to ask a question about the NASA Global Mosaic and how it doesn't
> match up with the data at a statewide zoom and and farther out.  I added
> a layer EROS that uses the projection 4326 and added it similarly to the
> mapbook.xml as the global mosaic.  At the statewide zoom, the images and
> the county layers do not match up.  As you zoom in, the lines approach
> the correct placement on the map.
> You can see the example of this at this site.
> http://gis.wrc.mnsu.edu/mrmp/geomoose.html
> I noticed Devon Piernot had an issue with this on October 15, 2009 and
> didn't see a response on the forums to his question.  Also, Efstathios
> Arapostathis remarked about having problems with this also.  I just
> installed GM 2.0.1 yesterday and had only made changes to the
> mapbook.xml by adding some layers.
> Any suggestions?  I can send the mapbook if need be.
> Thanks,
> Rick
> Rick Moore
> GIS Research Analyst
> Water Resources Center
> 184 Trafton Science Center South
> Minnesota State University, Mankato
> Mankato, MN   56001
> (507) 389-3267
> http://mavdisk.mnsu.edu/moorer2/
> *From:* Devon Piernot [mailto:piernotd at uwplatt.edu]
> *Sent:* Thursday, October 15, 2009 6:12 PM
> *To:* geomoose-users
> *Subject:* [Geomoose-users] NASA OnEarth wms
> First off, thank you to everyone who has helped my application get this far.
> As with the demo, I am trying to use the NASA global mosaic in my
> geomoose application, but I may be having some problems with
> projections.  I have defined EPSG:3071, which is the Wisconsin
> Transverse Mercator http://www.spatialreference.org/ref/epsg/3071/ and
> all of my own data is in this projection, but the global mosaic does not
> recognize it.  When I leave the wms in EPSG:4326 the image shows up, but
> it matches the map less and less at smaller scales.  This can be seen on
> the demo here: http://gis.swwrpc.org/geomoose2/geomoose.html (zoom in
> and it looks ok, but zoom out and it is way off).
> I see that the default projection for the global mosaic is EPSG:4326,
> does this mean that I cannot reproject it in geomoose 2.0?
> I followed the instructions here:
> http://www.geomoose.org/moose/howto/wms_project.html but to no avail,
> which makes me believe it could be a problem with my configuration
> somehow.  Should I instead write a mapfile to take the wms?
> Here is the code from my mapbook (with the default projection):
> <map-source name="nasa" type="wms" tiled="false" projection="EPSG:4326">
>         <url>http://wms.jpl.nasa.gov/wms.cgi</url>
>         <layer name="global_mosaic"/>
>         <param name="format" value="image/jpeg" reproject="true"/>
>     </map-source>
> ...and here is my projection:
> Proj4js.defs["EPSG:3071"] = "+title= NAD83(HARN) / Wisconsin Transverse
> Mercator +proj=tmerc +lat_0=0 +lon_0=-90 +k=0.9996 +x_0=520000
> +y_0=-4480000 +ellps=GRS80 +units=m +no_defs";
> Thank you all for your help
> Devon Piernot
> GIS / Web Developer
> Southwestern Wisconsin Regional Planning Commission
> (608) 342-6065
> piernotd at uwplatt.edu <mailto:piernotd at uwplatt.edu>
> www.swwrpc.org <http://www.swwrpc.org>
> Return on Information:
> Google Enterprise Search pays you back
> Get the facts.
> http://p.sf.net/sfu/google-dev2dev
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
Name: Rick Moore.vcf
Type: text/x-vcard
Desc: Rick Moore.vcf
Url : http://lists.osgeo.org/pipermail/geomoose-users/attachments/20091210/1290573e/RickMoore.vcf
More information about the Geomoose-users mailing list
