[Geomoose-users] Problem with print.
Dan Little danlittle at yahoo.com
Fri Dec 11 09:52:49 EST 2009
Mapserver should not have a slash, it's the path to mapserver on your server... if you mapserv bin is in the cgi-bin directory then it should just be "/cgi-bin/mapserv".
Also the server name should not have "http://" or a trailing "/".  The server name is used to build URL's for printing.
----- Original Message ----
> From: CoFIS Web <coffee at uni-bonn.de>
> Cc: "geomoose-users at lists.sourceforge.net" <geomoose-users at lists.sourceforge.net>
> Sent: Fri, December 11, 2009 8:50:24 AM
> Subject: Re: [Geomoose-users] Problem with print.
> Ups,
> you were right. I've got the trailing slashes now for the Linux settings
> as well:
> [paths]
> root=/srv/coffeeshop/map/
> temp=/tmp/cofis/
> mapserver_url=/mapserver/cgi-bin/mapserv/
> server_name=http://www.cofis.info/
> mapbook
> /cgi-bin/mapserv
> Does cgi-bin/mapserv in the mapbook need a slash as well? I tried both
> ways with no success.
> What about server_name - is this only the URL to the server or would it
> be the URL to GeoMoose (http://www.cofis.info/atlas in my case)
> Thanks,
> Nils
> CoFIS Web schrieb:
> > Len,
> > I checked - both do have trailing slashes.
> > What next?
> > Nils
> > Len Kne schrieb:
> >> Nils
> >> Try checking the mapfile_root parameter in the mapbook and root in
> settings.ini.  I believe both should have trailing slashes.
> >> Len
> >> -----Original Message-----
> >> From: CoFIS Web [mailto:coffee at uni-bonn.de]
> >> Sent: Friday, December 11, 2009 6:17 AM
> >> To: bfraser at geoanalytic.com
> >> Cc: geomoose-users at lists.sourceforge.net; jefe rodolfo pereira da silva
> >> I also got only blank pages when printing (GM 2.0.1, no matter what
> >> quality). The resulting files are of 0kb file size.
> >> I put "MAXSIZE 10000" in my globals.map as suggested earlier by Len.
> >> Where (which file) and how can I use "printf" statements?
> >> Thanks,
> >> Nils
> >> Brent Fraser schrieb:
> >>> Try to track down the problem by putting printf statements in the printing
> >>> PHP functions.
> >>>> Hi,
> >>>> I have problem with print. Only blank page appear.
> >>>> Someone have a tips to resolve it?
> >>>> Thanks for attention,
> >>>> Jefe Rodolfo Silva
> >>>> Analista de SIG
> >>>> (65) 3301-2426
> >>>> http://189.59.94.5/consis.html
> >>>> Join us December 9, 2009 for the Red Hat Virtual Experience,
> >>>> a free event focused on virtualization and cloud computing.
> >>>> Attend in-depth sessions from your desk. Your couch. Anywhere.
> >>>> http://p.sf.net/sfu/redhat-sfdev2dev
> >>>> _______________________________________________
> >>>> Geomoose-users mailing list
> >>>> Geomoose-users at lists.sourceforge.net
> >>>> https://lists.sourceforge.net/lists/listinfo/geomoose-users
> Center for Development Research
> Department of Ecology and Resource Management
> Walter-Flex-Strasse 3
> 53113 Bonn (Germany)
> Tel.:   +49 (0) 228 - 73-1793
> FAX:    +49 (0) 228 - 73-1889
> E-Mail: coffee at uni-bonn.de
> Web:    http://www.cofis.info/atlas
>          http://www.coffee.uni-bonn.de
> Return on Information:
> Google Enterprise Search pays you back
> Get the facts.
> http://p.sf.net/sfu/google-dev2dev
More information about the Geomoose-users mailing list
