[Geomoose-users] Search issue - no results
Dan Little danlittle at yahoo.com
Wed Dec 16 10:06:49 EST 2009
Did you check out:
http://www.geomoose.org/moose/services/query.php.html
Just to make sure... some of the settings will need changed to work with query.php, it is not a 1:1 exchange with itemquery.php
----- Original Message ----
> From: CoFIS Web <coffee at uni-bonn.de>
> To: GeoMoose Mailing list <geomoose-users at lists.sourceforge.net>
> Sent: Wed, December 16, 2009 9:01:41 AM
> Subject: Re: [Geomoose-users] Search issue - no results
> I pulled query.php from svn and still the same - no results.
> I checked the field names and strings I am searching for to exist in my
> shp-file.
> Nils
> Dan Little schrieb:
> > Actually, Len and Brian are running query.php with 2.0.1 installations.
> There's just no "package" to download.  We're currently trying to put the trunk
> code, "through the paces."  In my opinion, there are MANY fixed bugs with the
> current trunk and very few new ones.
> >> From: CoFIS Web
> >> Cc: Dan Little ; Len Kne
> >> Sent: Wed, December 16, 2009 8:37:59 AM
> >> Dan Little schrieb:
> >>> Getting the new query service will require pulling from SVN/trunk as it is
> >> technically a 2.2 feature.
> >> Too bad, I rather stick with 2.0.1 for the official version.
> >> Anyway, no luck using the patterns in the demo from the downladable packages
> for
> >> GM 2.0.1. The query still does not return any results.
> >> One thing that I find strange is, that if I mess up the
> >> php/itemquery.php to something like php/nothing.php, GM
> >> does not return an error but the "No results found for your query!". So I
> think
> >> it doesn´t even call the service (Yes, I cleared the cache and reloaded FF).
> >> Nils
> >> My mapbook service now looks like
> >>   php/itemquery.php
> >>       Wereda
> >>       Region
> >> All the rest is still the same:
> >> service="search_admin" selectable="false"/>
> >> In my mapfile in
> >> METADATA
> >> 'identify_record'    'tool_identify/wereda_identify.html'
> >> 'itemquery'        'tool_select/admin_04_wereda_itemquery.html'
> >> #'itemquery-filteritem'    'region'
> >> 'itemquery-filter'    '/.*[qstring].*/i'
> >> 'qstring_validation_pattern'    '.'
> >> END #METADATA
> >> admin_04_wereda_itemquery.html says
> >> [wereda]
> >> [region]
> >> src="images/toolbar/zoomto.png" border="0" title="Click here to zoom
> >> selected wereda">
> Center for Development Research
> Department of Ecology and Resource Management
> Walter-Flex-Strasse 3
> 53113 Bonn (Germany)
> Tel.:   +49 (0) 228 - 73-1793
> FAX:    +49 (0) 228 - 73-1889
> E-Mail: coffee at uni-bonn.de
> Web:    http://www.cofis.info/atlas
>          http://www.coffee.uni-bonn.de
> This SF.Net email is sponsored by the Verizon Developer Community
> Take advantage of Verizon's best-in-class app development support
> A streamlined, 14 day to market process makes app distribution fast and easy
> Join now and get one step closer to millions of Verizon customers
> http://p.sf.net/sfu/verizon-dev2dev
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users mailing list
