[Geomoose-users] Search issue - no results
CoFIS Web coffee at uni-bonn.de
Thu Dec 17 07:57:56 EST 2009
My last post referred to a search for items in "region". My service
looks like:
<service name="search_admin_new">
   <url>php/query.php</url>
   <step type="input">
     <input type="select" name="fieldname0" title="Search By:">
       <option value="wereda">Wereda</option>
       <option value="region">Region</option>
     </input>
     <input type="hidden" name="comparitor0" value="like-icase"/>
     <input type="user" name="value0" title=""/>
     <input type="hidden" name="layer0" value="administration/wereda"/>
     <input type="hidden" name="template0" value="itemquery"/>
     <input type="hidden" name="highlight" value="true"/>
     <input type="hidden" name="mode" value="search"/>
   </step>
</service>
<tool name="search_admin_new" title="Search" type="service"
service="search_admin_new" selectable="false"/>
Thanks,
Nils
Dan Little schrieb:
> Can you send the new service entry for query.php?
> ----- Original Message ----
>> From: CoFIS Web <coffee at uni-bonn.de>
>> To: Len Kne <lkne at houstoneng.com>
>> Cc: GeoMoose Mailing list <geomoose-users at lists.sourceforge.net>
>> Sent: Thu, December 17, 2009 5:41:52 AM
>> Subject: Re: [Geomoose-users] Search issue - no results
>> This is what I get if I comment out error reporting in query.php:
>> I searched for "Oromia" & it returns:
>> Warning: [MapServer Error]: msQueryByRect(): No matching record(s)
>> found. in /srv/www/geomoose/2.0.1/htdocs/php/query.php on line 317
>> Warning: [MapServer Error]: msEvalExpression: Failed to parse
>> expression: ("Oromia" =~ /.*(o|O)(r|R)(o|O)(m|M)(i|I)(a|A).*/) in
>> Warning: [MapServer Error]: msyyparse(): syntax error in
>> GM parses through the table but for some reason does not recognise the
>> entries with "Oromia" as such. ...
>> Any suggestions?
>> Nils
>> Len Kne schrieb:
>>> In query.php or itemquery.php, try commenting out the error suppression, like
>> this:
>>> #error_reporting(E_ERROR | E_PARSE);
>>> That might give some further information.  Also in Firebug, check the param
>> values being sent to make sure they look right.  Maybe the extent is wrong? -
>> speaking from frustrating experience here.
>>> Len
>>> -----Original Message-----
>>> From: CoFIS Web [mailto:coffee at uni-bonn.de]
>>> Sent: Wednesday, December 16, 2009 9:06 AM
>>> To: Len Kne
>>> alright, so how can I start tracking down the issue in my app?
>>> Nils
>>> Len Kne schrieb:
>>>> I can confirm that using query.php with 2.0.1 works just fine, we have
>> several sites with this combination.
>>>> Len
>>>> From: Dan Little [mailto:danlittle at yahoo.com]
>>>> Sent: Wednesday, December 16, 2009 8:44 AM
>>>> To: coffee at uni-bonn.de; GeoMoose Mailing list
>>>> Cc: Len Kne
>>>> Actually, Len and Brian are running query.php with 2.0.1 installations.
>> There's just no "package" to download.  We're currently trying to put the trunk
>> code, "through the paces."  In my opinion, there are MANY fixed bugs with the
>> current trunk and very few new ones.
>>>>> From: CoFIS Web
>>>>> To: GeoMoose Mailing list
>>>>> Cc: Dan Little ; Len Kne
>>>>> Sent: Wed, December 16, 2009 8:37:59 AM
>>>>> Dan Little schrieb:
>>>>>> Getting the new query service will require pulling from SVN/trunk as it is
>>>>> technically a 2.2 feature.
>>>>> Too bad, I rather stick with 2.0.1 for the official version.
>>>>> Anyway, no luck using the patterns in the demo from the downladable packages
>> for
>>>>> GM 2.0.1. The query still does not return any results.
>>>>> One thing that I find strange is, that if I mess up the
>>>>> php/itemquery.php to something like php/nothing.php, GM
>>>>> does not return an error but the "No results found for your query!". So I
>> think
>>>>> it doesn´t even call the service (Yes, I cleared the cache and reloaded FF).
>>>>> Nils
>>>>> My mapbook service now looks like
>>>>>   php/itemquery.php
>>>>>       Wereda
>>>>>       Region
>>>>> All the rest is still the same:
>>>>> service="search_admin" selectable="false"/>
>>>>> In my mapfile in
>>>>> METADATA
>>>>> 'identify_record'    'tool_identify/wereda_identify.html'
>>>>> 'itemquery'        'tool_select/admin_04_wereda_itemquery.html'
>>>>> #'itemquery-filteritem'    'region'
>>>>> 'itemquery-filter'    '/.*[qstring].*/i'
>>>>> 'qstring_validation_pattern'    '.'
>>>>> END #METADATA
>>>>> admin_04_wereda_itemquery.html says
>>>>> [wereda]
>>>>> [region]
>>>>> src="images/toolbar/zoomto.png" border="0" title="Click here to zoom
>>>>> selected wereda">
>> Center for Development Research
>> Department of Ecology and Resource Management
>> Walter-Flex-Strasse 3
>> 53113 Bonn (Germany)
>> Tel.:   +49 (0) 228 - 73-1793
>> FAX:    +49 (0) 228 - 73-1889
>> E-Mail: coffee at uni-bonn.de
>> Web:    http://www.cofis.info/atlas
>>          http://www.coffee.uni-bonn.de
>> This SF.Net email is sponsored by the Verizon Developer Community
>> Take advantage of Verizon's best-in-class app development support
>> A streamlined, 14 day to market process makes app distribution fast and easy
>> Join now and get one step closer to millions of Verizon customers
>> http://p.sf.net/sfu/verizon-dev2dev
>> Geomoose-users mailing list
>> Geomoose-users at lists.sourceforge.net
>> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users mailing list
