[Geomoose-users] Search issue - no results
Dan Little danlittle at yahoo.com
Thu Dec 17 07:37:44 EST 2009
Can you send the new service entry for query.php?
----- Original Message ----
> From: CoFIS Web <coffee at uni-bonn.de>
> To: Len Kne <lkne at houstoneng.com>
> Cc: GeoMoose Mailing list <geomoose-users at lists.sourceforge.net>
> Sent: Thu, December 17, 2009 5:41:52 AM
> Subject: Re: [Geomoose-users] Search issue - no results
> This is what I get if I comment out error reporting in query.php:
> I searched for "Oromia" & it returns:
> Warning: [MapServer Error]: msQueryByRect(): No matching record(s)
> found. in /srv/www/geomoose/2.0.1/htdocs/php/query.php on line 317
> Warning: [MapServer Error]: msEvalExpression: Failed to parse
> expression: ("Oromia" =~ /.*(o|O)(r|R)(o|O)(m|M)(i|I)(a|A).*/) in
> Warning: [MapServer Error]: msyyparse(): syntax error in
> GM parses through the table but for some reason does not recognise the
> entries with "Oromia" as such. ...
> Any suggestions?
> Nils
> Len Kne schrieb:
> > In query.php or itemquery.php, try commenting out the error suppression, like
> this:
> > #error_reporting(E_ERROR | E_PARSE);
> > That might give some further information.  Also in Firebug, check the param
> values being sent to make sure they look right.  Maybe the extent is wrong? -
> speaking from frustrating experience here.
> > Len
> > -----Original Message-----
> > From: CoFIS Web [mailto:coffee at uni-bonn.de]
> > Sent: Wednesday, December 16, 2009 9:06 AM
> > To: Len Kne
> > alright, so how can I start tracking down the issue in my app?
> > Nils
> > Len Kne schrieb:
> >> I can confirm that using query.php with 2.0.1 works just fine, we have
> several sites with this combination.
> >> Len
> >> From: Dan Little [mailto:danlittle at yahoo.com]
> >> Sent: Wednesday, December 16, 2009 8:44 AM
> >> To: coffee at uni-bonn.de; GeoMoose Mailing list
> >> Cc: Len Kne
> >> Actually, Len and Brian are running query.php with 2.0.1 installations.
> There's just no "package" to download.  We're currently trying to put the trunk
> code, "through the paces."  In my opinion, there are MANY fixed bugs with the
> current trunk and very few new ones.
> >>> From: CoFIS Web
> >>> To: GeoMoose Mailing list
> >>> Cc: Dan Little ; Len Kne
> >>> Sent: Wed, December 16, 2009 8:37:59 AM
> >>> Dan Little schrieb:
> >>>> Getting the new query service will require pulling from SVN/trunk as it is
> >>> technically a 2.2 feature.
> >>> Too bad, I rather stick with 2.0.1 for the official version.
> >>> Anyway, no luck using the patterns in the demo from the downladable packages
> for
> >>> GM 2.0.1. The query still does not return any results.
> >>> One thing that I find strange is, that if I mess up the
> >>> php/itemquery.php to something like php/nothing.php, GM
> >>> does not return an error but the "No results found for your query!". So I
> think
> >>> it doesn´t even call the service (Yes, I cleared the cache and reloaded FF).
> >>> Nils
> >>> My mapbook service now looks like
> >>>   php/itemquery.php
> >>>       Wereda
> >>>       Region
> >>> All the rest is still the same:
> >>> service="search_admin" selectable="false"/>
> >>> In my mapfile in
> >>> METADATA
> >>> 'identify_record'    'tool_identify/wereda_identify.html'
> >>> 'itemquery'        'tool_select/admin_04_wereda_itemquery.html'
> >>> #'itemquery-filteritem'    'region'
> >>> 'itemquery-filter'    '/.*[qstring].*/i'
> >>> 'qstring_validation_pattern'    '.'
> >>> END #METADATA
> >>> admin_04_wereda_itemquery.html says
> >>> [wereda]
> >>> [region]
> >>> src="images/toolbar/zoomto.png" border="0" title="Click here to zoom
> >>> selected wereda">
> Center for Development Research
> Department of Ecology and Resource Management
> Walter-Flex-Strasse 3
> 53113 Bonn (Germany)
> Tel.:   +49 (0) 228 - 73-1793
> FAX:    +49 (0) 228 - 73-1889
> E-Mail: coffee at uni-bonn.de
> Web:    http://www.cofis.info/atlas
>          http://www.coffee.uni-bonn.de
> This SF.Net email is sponsored by the Verizon Developer Community
> Take advantage of Verizon's best-in-class app development support
> A streamlined, 14 day to market process makes app distribution fast and easy
> Join now and get one step closer to millions of Verizon customers
> http://p.sf.net/sfu/verizon-dev2dev
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users mailing list
