[Geomoose-users] Search issue - no results
CoFIS Web coffee at uni-bonn.de
Tue Dec 22 08:52:25 EST 2009
I do have
EXTENT -182486 360280 1689294 1495282
in my globals at MAP level.
I tried again and modified the original files - search works now
(itemquery.php) for unique results. It was probably a typo in my layer
paths or something.
I´ll start a new threat for the next search issue.
Thanks,
Nils
Dan Little schrieb:
> Do you have the EXTENT set at the LAYER and/or MAP level in your Mapfile?
> ----- Original Message ----
>> From: CoFIS Web <coffee at uni-bonn.de>
>> To: Dan Little <danlittle at yahoo.com>
>> Cc: GeoMoose Mailing list <geomoose-users at lists.sourceforge.net>
>> Sent: Thu, December 17, 2009 6:57:56 AM
>> Subject: Re: [Geomoose-users] Search issue - no results
>> My last post referred to a search for items in "region". My service looks like:
>>   php/query.php
>>       Wereda
>>       Region
>> service="search_admin_new" selectable="false"/>
>> Thanks,
>> Nils
>> Dan Little schrieb:
>>> Can you send the new service entry for query.php?
>>>> From: CoFIS Web
>>>> To: Len Kne
>>>> Sent: Thu, December 17, 2009 5:41:52 AM
>>>> This is what I get if I comment out error reporting in query.php:
>>>> I searched for "Oromia" & it returns:
>>>> Warning: [MapServer Error]: msQueryByRect(): No matching record(s) found. in
>> /srv/www/geomoose/2.0.1/htdocs/php/query.php on line 317
>>>> Warning: [MapServer Error]: msEvalExpression: Failed to parse expression:
>> ("Oromia" =~ /.*(o|O)(r|R)(o|O)(m|M)(i|I)(a|A).*/) in
>>>> Warning: [MapServer Error]: msyyparse(): syntax error in
>>>> GM parses through the table but for some reason does not recognise the
>> entries with "Oromia" as such. ...
>>>> Any suggestions?
>>>> Nils
>>>> Len Kne schrieb:
>>>>> In query.php or itemquery.php, try commenting out the error suppression,
>> like
>>>> this:
>>>>> #error_reporting(E_ERROR | E_PARSE);
>>>>> That might give some further information.  Also in Firebug, check the param
>>>> values being sent to make sure they look right.  Maybe the extent is wrong? -
>> speaking from frustrating experience here.
>>>>> Len
>>>>> -----Original Message-----
>>>>> From: CoFIS Web [mailto:coffee at uni-bonn.de] Sent: Wednesday, December 16,
>> 2009 9:06 AM
>>>>> To: Len Kne
>>>>> alright, so how can I start tracking down the issue in my app?
>>>>> Nils
>>>>> Len Kne schrieb:
>>>>>> I can confirm that using query.php with 2.0.1 works just fine, we have
>>>> several sites with this combination.
>>>>>> Len
>>>>>> From: Dan Little [mailto:danlittle at yahoo.com] Sent: Wednesday, December 16,
>> 2009 8:44 AM
>>>>>> To: coffee at uni-bonn.de; GeoMoose Mailing list
>>>>>> Cc: Len Kne
>>>>>> Actually, Len and Brian are running query.php with 2.0.1 installations.
>>>> There's just no "package" to download.  We're currently trying to put the
>> trunk code, "through the paces."  In my opinion, there are MANY fixed bugs with
>> the current trunk and very few new ones.
>>>>>>> From: CoFIS Web To: GeoMoose Mailing list Cc: Dan Little ; Len Kne Sent:
>> Wed, December 16, 2009 8:37:59 AM
>>>>>>> Dan Little schrieb:
>>>>>>>> Getting the new query service will require pulling from SVN/trunk as it
>> is
>>>>>>> technically a 2.2 feature.
>>>>>>> Too bad, I rather stick with 2.0.1 for the official version.
>>>>>>> Anyway, no luck using the patterns in the demo from the downladable
>> packages
>>>> for
>>>>>>> GM 2.0.1. The query still does not return any results.
>>>>>>> One thing that I find strange is, that if I mess up the php/itemquery.php
>> to something like php/nothing.php, GM does not return an error but the "No
>> results found for your query!". So I
>>>> think
>>>>>>> it doesn´t even call the service (Yes, I cleared the cache and reloaded
>> FF).
>>>>>>> Nils
>>>>>>> My mapbook service now looks like
>>>>>>>   php/itemquery.php
>>>>>>>           Wereda
>>>>>>>       Region
>>>>>>> All the rest is still the same:
>>>>>>> service="search_admin" selectable="false"/>
>>>>>>> In my mapfile in
>>>>>>> METADATA
>>>>>>> 'identify_record'    'tool_identify/wereda_identify.html'
>>>>>>> 'itemquery'        'tool_select/admin_04_wereda_itemquery.html'
>>>>>>> #'itemquery-filteritem'    'region'
>>>>>>> 'itemquery-filter'    '/.*[qstring].*/i'
>>>>>>> 'qstring_validation_pattern'    '.'
>>>>>>> END #METADATA
>>>>>>> admin_04_wereda_itemquery.html says
>>>>>>> [wereda]
>>>>>>> [region]
>>>>>>> src="images/toolbar/zoomto.png" border="0" title="Click here to zoom
>>>>>>> selected wereda">
>>>> -- Center for Development Research
>>>> Department of Ecology and Resource Management
>>>> Walter-Flex-Strasse 3
>>>> 53113 Bonn (Germany)
>>>> Tel.:   +49 (0) 228 - 73-1793
>>>> FAX:    +49 (0) 228 - 73-1889
>>>> E-Mail: coffee at uni-bonn.de
>>>> Web:    http://www.cofis.info/atlas
>>>>          http://www.coffee.uni-bonn.de
>>>> This SF.Net email is sponsored by the Verizon Developer Community
>>>> Take advantage of Verizon's best-in-class app development support
>>>> A streamlined, 14 day to market process makes app distribution fast and easy
>>>> Join now and get one step closer to millions of Verizon customers
>>>> http://p.sf.net/sfu/verizon-dev2dev
>>>> Geomoose-users mailing list
>>>> Geomoose-users at lists.sourceforge.net
>>>> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users mailing list
