[Geomoose-users] Search results - layouting
FRANZ OKYERE franzzoa at hotmail.com
Mon Dec 28 10:15:08 EST 2009
Hi Nils, My workaround is to take the sprite control class out (from your html template- I don't use the template anyway) and use the find.png, which is the image you wanna show, in an img tag just before the anchored pin or owner name. Hope this help. Cheers Franz.
> Date: Mon, 28 Dec 2009 15:39:33 +0100
> From: coffee at uni-bonn.de
> To: franzzoa at hotmail.com
> CC: geomoose-users at lists.sourceforge.net
> Subject: Re: [Geomoose-users] Search results - layouting
> Thanks Franz,
> which file would I have to modify - any idea?
> Nils
> FRANZ OKYERE schrieb:
> > Nils, I also used print to output my search result and realised that the
> > sprite is the cause of the multiple lines of text.  Franz. GIs specialist.
> >  > Date: Tue, 22 Dec 2009 17:50:09 +0100
> >  > To: geomoose-users at lists.sourceforge.net
> >  > Subject: [Geomoose-users] Search results - layouting
> >  > Currently my search results are wraped in very short lines -
> >  > i.e. "Rural Diredawa" will be printed in two lines although there would
> >  > be enough space to print it into one.
> >  > Which is the file to format the results more pretty. My html template
> >  > looks like:
> >  > <a class='sprite-control sprite-control-find-selected'
> >  > style="padding-left: 22px"
> > href="javascript:GeoMOOSE.changeLayerUrl('highlight','php/itemquery.php');
> >  > GeoMOOSE.updateLayerParameters('highlight', {'qitem' : 'wereda',
> >  > 'qstring' : '[wereda]', 'layer' : 'administration/all'});
> >  > GeoMOOSE.turnLayerOn('highlight/all');
> > GeoMOOSE.zoomToExtent([shpminx],[shpminy],[shpmaxx],[shpmaxy]);">[wereda]</a><br/>
> >  > I tried to put that link into a table column. However no matter how
> >  > large I define <td width=...> the text still gets wraped - even though
> >  > there would be lots of space to the right.
> >  > Thanks,
> >  > Nils
> >  > Center for Development Research
> >  > Department of Ecology and Resource Management
> >  > Walter-Flex-Strasse 3
> >  > 53113 Bonn (Germany)
> >  > Tel.: +49 (0) 228 - 73-1793
> >  > FAX: +49 (0) 228 - 73-1889
> >  > E-Mail: coffee at uni-bonn.de
> >  > Web: http://www.cofis.info/atlas
> >  > http://www.coffee.uni-bonn.de
> >  > This SF.Net email is sponsored by the Verizon Developer Community
> >  > Take advantage of Verizon's best-in-class app development support
> >  > A streamlined, 14 day to market process makes app distribution fast
> > and easy
> >  > Join now and get one step closer to millions of Verizon customers
> >  > http://p.sf.net/sfu/verizon-dev2dev
> >  > _______________________________________________
> >  > Geomoose-users mailing list
> >  > Geomoose-users at lists.sourceforge.net
> >  > https://lists.sourceforge.net/lists/listinfo/geomoose-users
> > View your other email accounts from your Hotmail inbox. Add them now.
> > <http://clk.atdmt.com/UKM/go/186394592/direct/01/>
> > A streamlined, 14 day to market process makes app distribution fast and easy
_________________________________________________________________
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20091228/204380e4/attachment.html
More information about the Geomoose-users mailing list
