[Geomoose-users] Uploading Geomoose Api to a server
Dan Little danlittle at yahoo.com
Mon Dec 28 11:03:36 EST 2009
Edit your "geomoose_globals.map" file... the OUTPUTFORMAT clauses are in there as is IMAGETYPE.  You'll need to set IMAGETYPE to GIF or PNG.
>From: Efstathios Arapostathis <e.arapostathis at gmail.com>
>To: Dan Little <danlittle at yahoo.com>
>Sent: Mon, December 28, 2009 9:58:43 AM
>Subject: Re: [Geomoose-users] Uploading Geomoose Api to a server
>>OK,
>  At first thank you a lot for the useful tip.
>   I had a problem with the path. I fixed it and now
>I'm having this: "loadOutputFormat(): General error message. OUTPUTFORMAT clause references driver AGG/PNG, but this driver isn't configured."
>From the hosting company  they answered that they currently:
>"do not support 'AGG/PNG' driver due to the issue with GD library on our cPanel (the control panel) system. We will try to fix this issue on the next software upgrade.
>At the meantime you can use the other drivers, ie 'PNG', 'GIF', 'JPEG'. "
>I google the "AGG/PNG driver" and found out that the output format clause is set through the map file. But my map file doesn't have anything about outputformat, in order to change it.
>What should I do?
>Thanks a lot again :)
>On Mon, Dec 28, 2009 at 5:31 PM, Dan Little <danlittle at yahoo.com> wrote:
>Well, then we need to see why you are getting pink images. :-)
>>In firefox, goto "Tools" then "Page Info", click on the "Media" tab.  Then click on the "Media" tab, and scroll down until you see the URL of the images that are broken.  They will be greyed out.  More than most likely you have a mapserver configuration issue.
>>>To: Dan Little
>>>Sent: Mon, December 28, 2009 9:27:41 AM
>>>Yes, exactly, I'm getting pink images!!
>>>On Mon, Dec 28, 2009 at 4:05 PM, Dan Little <danlittle at yahoo.com> wrote:
>>>I think we're going to need more specifics and/or a link to your hosted site to do some diagnostics.
>>>>Are you getting "pink images" in the map viewer? Is the Catalog showing?
>>>>>To: geomoose-users at lists.sourceforge.net
>>>>>Sent: Thu, December 24, 2009 11:25:53 AM
>>>>>Subject: [Geomoose-users] Uploading Geomoose Api to a server
>>>>>>>>>>Hello,
>>>>>    I recently bought some space in a gis-server and I'm trying to upload the geomoose api and I' having some problems.
>>>>>I know the map server url (http://www.myurl/cgi-sys/mapserv/) and I' m changing it in the mapbook. I also change the mapfileroot setting.
>>>>>Then I upload the folder geomoose2 to a path, but nothing is working. The interface is loaded but none map is loaded....
>>>>>I don't know if it is helping but the server runs Linux and I have geomoose for ms4w installed on my pc (windows vista)
>>>>>Thanks
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20091228/fba975b6/attachment.html
More information about the Geomoose-users mailing list
