[Geomoose-users] Zoom to Results (GM2)
Brian Fischer bfischer at houstoneng.com
Wed Dec 30 14:40:16 EST 2009
Franz,
The only way to get GM 2.2 at this point is to install Toirtoise SVN and download it from the SVN repository in source forge.  We haven't' made a MS4W ready .zip download file yet.  We probably won't get to that for a couple more weeks.  It will be a bit of a learning curve if you have never used SVN software and you'll have to figure out how to put the trunk code into the MS4W directory structure if you're using that.
http://tortoisesvn.tigris.org/
The GM repository is at https://geomoose.svn.sourceforge.net/svnroot/geomoose.   You'll want the moose2-trunk folder.  That is where we commit all the latest code to.
Brian Fischer, CFM  GIS Project Manager
Houston Engineering, Inc.
Phone: W: 763.493.4522 / M: 763.229.2734
From: FRANZ OKYERE [mailto:franzzoa at hotmail.com]
Sent: Wednesday, December 30, 2009 12:23 PM
To: geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] Zoom to Results (GM2)
Hi Matt, please write a simple algorithm in query.php that finds the minx, miny, maxx, maxy, using bounds method, loosing through results- kinda minimum and maximum algorithm. Meanwhile I don't know where to download the GM2.2. I need it badly. Thanks.  Franz. GIS Specialist.
Date: Wed, 30 Dec 2009 10:20:15 -0600
Subject: [Geomoose-users] Zoom to Results (GM2)
In the documentation for the new query service, I notice a "zoom_to_first" parameter.  I would like to have the functionality to zoom to the entire result set.
Is this parameter possible, and just no yet documented?  If not, what might I do to make this possible?
Thanks in advance for your assistance.
Matt Syvertson
Richland County GIS Coordinator
418 2nd Ave N
Wahpeton, ND 58075
msyvertson at co.richland.nd.us<mailto:matthews at co.richland.nd.us>
Voice: 701-642-7860  Fax: 701-642-7746
Have more than one Hotmail account? Link them together to easily access both.<%20http:/clk.atdmt.com/UKM/go/186394591/direct/01/>
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20091230/355b4f4f/attachment.html
More information about the Geomoose-users mailing list
