[Geomoose-users] Problem with the Encoding(character set) of the select results
Dan Little danlittle at yahoo.com
Mon Feb 2 10:31:01 EST 2009
This is something other folks have had an issue with too.  If anyone has come up with a complete solution PLEASE post it?
Any chance you can use Firebug to determine the character encoding mapserver is returning?
To: geomoose-users at lists.sourceforge.net
Sent: Monday, February 2, 2009 8:41:47 AM
Subject: [Geomoose-users] Problem with the Encoding(character set) of the select results
Hi All,
I'm facing a problem in the display of the query by
select results in the right frame under Information tab.
The problem is that my database has arabic characters,
and these arabic characters appear as symbols in the results
(identify.html).
I tried to set the encoding of this html file but it
failed also.
Help Please ..
Thanks
Mohmaher
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20090202/3748070f/attachment.html
More information about the Geomoose-users mailing list
