[Geomoose-users] Re : From UMT-15 to UMT-32 Projection
armand noel abasoh at yahoo.fr
Wed Feb 11 05:43:57 EST 2009
Hi Moh.Mayer,
It's working now, the issue was with  a wrong path in the 'countydemo.xml' file.
Thanks for your help.
Rgrds
Armand Basoh, PMP
De : Moh.Maher <mohmaher at hotmail.com>
À : armand noel <abasoh at yahoo.fr>
Envoyé le : Mercredi, 11 Février 2009, 10h59mn 44s
Objet : Re: [Geomoose-users] From UMT-15 to UMT-32 Projection
Armand,
Make sure that your shapefile is located in the same
path you put in the map file.
Make sure that the extents value that you have
changed is valid  and following the same coordinate
system/projection for your shapefile ( you can simply use ogrinfo to know
the  extents for your shapfile) .
Add to your map file  the projection that your
shapefile uses and its parameters.
Preferable as you are still a beginner that you use
the free- open source  Quantum GIS to load your shapefile to make sure it
is displaying OK, and second Quantum GIS can create a valid map file for your
shapefile, that you can edit later or use in Mapserver or Geomoose
app.
Try and let us know ..
Regards,
Moh.Maher
Sent: Wednesday, February 11, 2009 12:33 PM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] From UMT-15 to UMT-32
Projection
I want to create a new application with Geomoose on a Windows Xp
installation. But it is not working.
My data is in UMT Zone 32
projection. To create the new application I fellow this Step:
1 - I
create a new folder in C:\ms4w\apps\GeoMOOSE\maps_countydemo\ call
'departements'
2 - In 'countydemo-configuration.js', I make these
changes:
change the line 26 to
    var INITIAL_VIEW =
'-168958.001,126687.001,1941235.001,1471051.001';
change the line 217
to
    var MAP_COORDINATE_SYSTEM = 'UTM-32';
Change the
line 379 to
    var MAP_MAXSCALE = 1000000000000;
3 -
In 'countydemo.xml', I remove all the layer and I add only one
layer
  <map title="departement"
default="true">
<file>/ms4w/apps/GeoMOOSE/maps_countydemo/departements/departement.map</file>
</map>
4 - In 'C:\ms4w\apps\GeoMOOSE\maps_countydemo\departements'
folder, i create the MAPfiles with this contain:
depertement.map:
MAP
NAME 'mn_departement'
    SIZE 800 650
STATUS ON
    EXTENT -168958.001 126687.001 1941235.001
1471051.001
    UNITS METERS
    FONTSET
'../fonts/fontset.list'
    SYMBOLSET
'../symbols/symbol.sym'
    TRANSPARENT
TRUE
    QUERYMAP
STATUS ON
        STYLE
SELECTED
    END
WEB
        QUERYFORMAT
"text/xml"
        INCLUDE
"../temp_directory.map"
    END
LEGEND
        STATUS ON
END
    LAYER
NAME 'departement'
        DATA
'./Departement_region_region.shp'
STATUS DEFAULT
        TYPE
POLYGON
        CLASS
        NAME 'departement'
        STYLE
             COLOR 0 200
0
     OUTLINECOLOR 0 0 0
             WIDTH
1
END
        END
    HEADER 'imagemap_header.xml'
    TEMPLATE 'imagemap_record.xml'
    FOOTER 'imagemap_footer.xml'
END
END ## end
Map
The problem
that I have is that no map is displaying?
Have I miss something or
another parameter to ajust?
Is there any problem with the projection?
Should I have to write a new 'UMT.js' for UMT-32 to
Long/Lat?
Rgrds
Armand Basoh, PMP
Web
Develloper
 Ne pleurez pas si votre Webmail ferme. Récupérez
votre historique sur Yahoo! Mail
Create
and Deploy Rich Internet Apps outside the browser with
Adobe(R)AIR(TM)
software. With Adobe AIR, Ajax developers can use existing
skills and code to
build responsive, highly engaging applications that
combine the power of local
resources and data with the reach of the web.
Download the Adobe AIR SDK and
Ajax docs to start building applications
today-http://p.sf.net/sfu/adobe-com
Geomoose-users mailing
list
Geomoose-users at lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geomoose-users
      __________________________________________________________________________________________________
Ne pleurez pas si votre Webmail ferme ! Récupérez votre historique sur Yahoo! Mail ! http://fr.docs.yahoo.com/mail/transfert_mails.html
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20090211/575316e3/attachment.html
More information about the Geomoose-users mailing list
