[Geomoose-users] 2008 FSA Air Photo
Jim Klassen Jim.Klassen at ci.stpaul.mn.us
Wed Feb 11 09:42:14 EST 2009
For some reason I feel the need to give a more complete answer. First, if you are using MS4W and you don't know how/feel like rebuilding mapserver and it's dependancies from source, then Brian's answer stands.
GDAL does support some JP2 files through the libjasper library. Others can be supported by the MrSID, ECW, or Kakadu drivers but these options require third party libraries which have licensing terms which could be a problem for mass distribution under MS4W.
>>> "Fischer, Brian" <bfischer at houstoneng.com> 02/10/09 12:19 PM >>>
I asked the MS4W mailing list about this a while back and the response
that I got back is GDAL does not support the JP2 format those aerial
photos are being published in.  So the answer is no.
Brian Fischer
Houston Engineering, Inc.
Maple Grove, MN
(763) 493-4522
Sent: Tuesday, February 10, 2009 11:52 AM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] 2008 FSA Air Photo
Has anyone been able to get Geomoose / Mapserver to work with the jp2
files directly?  I would like to be able to use our 2008 air photos on
remote machines that do not have access to the WMS server.
Thanks
Mark Volz
GIS Specialist
Lyon County, MN
(507) 532-8218
More information about the Geomoose-users mailing list
